Results 1 to 7 of 7
Thread: When to add algaecide
    I have a poly quat question also.
    In closing my IG pool and using bleach and Poly quat should I shock first, then let the chlorine drop to normal then add polyquat and close?
    So I have the LG and have been using it all year with great results. My FC is about 4-6 with a cya of 60. What should I shock too? How low should it drop before I put the PolyQuat in? and then close. Last year I shocked, then added Polyquat, then the poly dropped the FC then reshocked and closed. ANd open to a green swamp. So what should I do different this year in West Virginia? I also have a mesh safety cover.
    Thanks
    Mike
    22,000 IG vinyl liner
    sand filter
    LQ 8 gallon
    Jacuzzi Hot Tub
    420 gallons
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: When to add algaecide
    Just shock to shock levels, let the chlorine drop to normal levels, add the PolyQuat which will end up lowering the FC even further (eventually it will go to zero, but you don't have to wait for that), make sure the PolyQuat dose is a full initial dose or larger and not just a maintenance dose, but do not add more chlorine after the PolyQuat (at least not at shock levels). See this post for what Buckman Labs, the makers of PolyQuat, said about closing a pool.
    Now I would be very surprised if the PolyQuat would last all winter long. You'll want to wait to close the pool as late as possible so the water is as cold as possible and then you'll want to open it as early as possible and get chlorine into it. Even with all of these precautions, it still may not work -- it just improves your odds. The only surefire way is to add chlorine on a regular basis to keep the FC up during the winter, but with pools that freeze over and no longer have circulation that isn't an option.
    Richard
    Oct 2007
    Cedar Hill, TN
    252
    Well, I guess I messed up on the closing part.
    I shocked, lowered PH, raised Alk, put in polyquat, put on the cover.
    Temp is still 78, but we will be gone for 2 weeks. I did not want to leave the pool open, or come back and have to close the pool.
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    Mantua, NJ
    80
    Quote Originally Posted by mikemedic
    Thanks
    Mike
    I have been wondering the same thing. I close late, pool is still open @72*, and open in late April to slightly green pool. Is the chlorine and polyquart just helping until the temps are very cold.
    May close this year without the polyquart and see what happens in the spring.
    I also have a mesh cover, which doesn't block the sun very well.
    Joe
    21k IG vinyl, 300 lb. sand filter, 1hp pump, Polaris 280 cleaner, 3/4hp booster pump, 240sq ft Fafco solar, Liquidator
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Are these products the same thing as polyquat 60?
    http://www.intheswim.com/Pool-Chemicals ... e-60-Plus/
    http://www.aqua-pool-warehouse.com/Cata ... oly_60.asp
    some info at the following site seems to indicate yes, but that they may be repackaged and lower concentrations?
    http://www.poolsolutions.com/gd/polyquat.html
    28 ft round Doughboy Sand Dollar II AGP, Aug 2008: 4 ft shallow, 6ft deep end: 24K gal approx Hayward Power-Flo Matrix
    1&1/2-HP 2-SPD Pump, Hayward 27-Inch Sand Filter with a little DE -(2) 4ftx20ft Solar Bear AGP Panels w/ Goldline auto-controller, 50ppm Borates And some day, maybe this year, a DECK!!!
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    I have an inground pool and use a meyco mesh cover. It definitely works and keeps out the sun. I closed the pool up with the water at 66. It got a bit warm on us and its now 68, but its been closed a week and just for kicks I tested it. FC is still at 5 and no algae. So I know the mesh cover is working just fine.
    I recommend them as I have had good luck.
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by amjohn
    Those are all PolyQuat 60 (the last site shows a PolyQuat 30 on the right which is the same substance, just at half the concentration). The "60" refers to having 60% concentration of the main ingredient. If you see the ingredients list, then look for something that says the following:
    Poly[oxyethylene(dimethyliminio)ethylene(dimethyliminio)ethylene dichloride]
    If you instead see any of the following, these are NOT PolyQuat but linear quats or other algaecides:
    Polydimethyldiallyammonium Chloride
    Alkyl dimethylbenzylammonium chloride
    Dimethyl Benzyl Ammonium Chloride
    Sodium Bromide
    Copper Carbonate
