Results 1 to 16 of 16
Thread: I'd like to try the BioActive product
    Noorm's Avatar
    Apr 2015
    San Jose, CA
    20
    I've been fighting algae with shock treatment, but because my CYA is in the 120 range, it takes a lot of CL. I'd like to try the BioActive product, but I see this warning " It is important to note, that your chlorine will attack the active ingredient in Bio-Active, so make sure your chlorine is at normal levels, around 2 - 6 PPM. " So now I must first get my FC down and I'm not sure how to do this. Seems to be a vicious circle. HIgh CYA requires huge FC to kill algae, but CYA reduction requires low FC.
    Anyone have experience with Jack's Magic chlorine reducer? Just based on cost it looks better than the chlorine neutralizer sold by Leslie's
    In ground concrete/plaster. Re-plastered 5 years ago Approx 30,000 Gal.
    Hayward 2 speed pump and C3030 cartridge filter. Taylor K-2006 test kit
    38,235
    Re: Bio-ACtive CYA Reducer Fine Print
    Quote Originally Posted by Noorm View Post
    Cheaper and easier to replace water usually. The FC will drop if you stop adding any chlorine due to the sun.
    Noorm's Avatar
    Apr 2015
    San Jose, CA
    20
    I agree, but I am subject to water usage constraints due to CA drought, so I have to look at alternatives. Also the FC with my 120 CYA is dropping very slowly.
    I think I'm between a rock and hard place: If I reduce FC, then use CYA reducer, the algae's gonna go crazy during the time it takes the CYA reducer's little bacteria to devour my CYA.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: I'd like to try the BioActive product
    Hi Noorm,
    as far as TFP is concerned, the jury is still out on the CYA reducer. There have been a coiuple or 3 TFPers give it a try with mixed results. ... So, just a message to let you know that it may, or not, work.
    Divin Dave,
    Noorm's Avatar
    Apr 2015
    San Jose, CA
    20
    Quote Originally Posted by Divin Dave View Post
    Hi Noorm,
    Thanks Dave. I'm probably gonna gise it a try, but I have to deal with my high FC first.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Why not just wait a week or 2 (don't add any chlorine during this time) you would then be
    very close to the recommended chlorine level to run it. In the instructions you're not supposed
    to add any stuff to your pool 7 days prior to the treatment any how.
    None of the other people trying this reducer out had Algae blooms pretty sure.
    It took about 1 1/2 weeks from the time i ordered the cya reducer to when it arrived.
    Waiting for my water to get up to 65 degrees, then applying this reducer. I'm at 120ppm cya as well.
    Dolphin E10 Cleaning Robot.
    Both Jack's Magic After Shock and Thiosulfate at Leslie's are effective. The main thing to watch for is that the required dosage can be a little variable. If you overshoot FC will go down to zero, and stay at zero until you add enough chlorine to use up all of the excess chlorine reducer.
    As borjis said, there shouldn't be any algae issues as long as you start the CYA reducer right after reducing the FC level.
    We don't know enough about the CYA reducer product to either recommend for or against it. Early reports have it working about 2/3rds of the time. That is promising, but not exactly trouble free just yet.
    Jul 2014
    Sacramento, CA
    241
    Just for comparison, watering 1/2 acre of grass with 1" of water (a common weekly amount, for better or worse) is 20000sf *1/12 = 1666cf * 7.48gal/cf = ~12,500gal, or around half of the water in your pool. I'm not advocating wasting water, but unless you're explicitly banned from filling pools at all (which must not include regular top-offs?) I submit that a one-time drain/refill to get CYA under control is a, well, drop in the bucket, and IMO better than adding more chemicals that may or may not have side effects. Once you get things in balance, you shouldn't need to keep draining/refilling.
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    Jul 2014
    Independence, KY
    220
    Quote Originally Posted by jmastron View Post
    Remember that a 1/2 acre lot, is not 1/2 of grass typically. By the time you take away the area for a driveway, sidewalks, landscaping, etc, you have far less area than 20,000sf.
    IG W/Vinyl Liner Oval 18x40, 21K gal, Oval 3'-8'
    Pentair Intelliflo VS Pump, Sand Filter
    Noorm's Avatar
    Apr 2015
    San Jose, CA
    20
    Thanks to all for your comments and suggestions. I'll give it a week to see if FC drops substantially, but so far in about 4 days, it's come down very little.
    As to the water restrictions, topping off is allowed, but filling is prohibited. As to the lawn water comparison, I agree, but my lawn is very small and while the pool partial drain and refill is indeed a drop in the big picture bucket, it will result in a 75-100% increase in my monthly usage which I think will be noticed.
    I have had no problems with water clarity, but the algae grows on the sides of the pool and on the steps. Is this considered "bloom"? Even with my FC at 35ppm, there is still some new stuff that I can brush off, but the walls do not come clean. Still have motley, splotchy stains.
    Noorm's Avatar
    Apr 2015
    San Jose, CA
    20
    After 6 days FC has only dropped about 10 points (35 to 25). Is the drop time linear? If so it'll be another 2 weeks before it's low enough to use the BioActive CYA reducer.
    38,235
    It is not linear ... usually the FC loss is a % that is based on your CYA level. So, in fact you should loose less as the FC level gets lower.
    Noorm's Avatar
    Apr 2015
    San Jose, CA
    20
    Well, since I've stopped adding CL, I'm seeing the algae re-assert itself, so if I wait for the FC to drop by itself, I'm afraid it will be pretty bad before the BioActive has done it's work and I can slam the pool. I believe I need to get the CL reducer and get things moving.
    38,235
    From what I have seen ... not sure the BioActive is worth the hassle. But good luck if you try it.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I should know this already, but can't remember. Can the product be used in an Algae Pool?
    Essential Links:
    They have never mentioned it being a problem. They just say to be sure to maintain the FC around 2-3 ppm, which will be difficult.
