Thread: Who levels pool during build?
    dtrujillo63's Avatar
    Feb 2015
    Los Angeles
    33
    I'm curious, who is suppose to level the pool during the build process? I can't imagine the steel guys setting the rebar perfectly level. Is it safe to assume that the gunite guys do the final level when they're troweling the pool? Should I expect the pool shell to be perfectly level after gunite or is a little variance common?
    30 x 20 IG Play Pool + 7' Spa ~16K Gallons, French Gray Plaster, Pentair Intelliflow VS, Pentair CCP420, Pentair MasterTemp 400K Heater, Intellibrite LEDs.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Who levels pool during build?
    Variance is common. Everyone is leveling as they go, wood frame, rebar, gunite. The critical level point is the waterline tile. That will be set correctly and then the coping is usually level as well. But, the only one that your eye will see if it is off is the waterline tile.
    Normally there is either a wooden rim or a string line placed around the hole (once it is dug out) and that rim/string is carefully leveled. The rebar and gunite people base their work on that wooden rim/string. Then the tile people (if you have water line tile) do their own leveling because any errors in the tile are just so obvious once the pool is complete.
    DFW, TX
    24,514
    This wooden rim. It is leveled with a transit level.
    Sep 2014
    Riverside/Ca
    4
    My excavation company did the initial leveling. They based it on the highest point of my existing patio and what type of coping I was planning on doing. (Pour in place cantilever) some coping is thicker than others so this comes into play with drainage/slope. My gunite company also leveled their work as needed, and the concrete guys who poured the coping and deck did the same during the prep work.
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Thanks everyone. This is good information to know. And just in time since our tile work is around the corner. Take care! Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
