Thread: Maintaining BBB on vacation
    Mar 2015
    Elkton, Maryland
    124
    So with the BBB method, how would you keep a pool that is in good shape maintained while on vacation for a weekend or a week?
    1978 Sylvan IG Gunite pool (around 18,000 gallon)
    Hayward Vari-Flo DE Filter and 3/4 HP Super Pump - installed in 1991
    TF-100XL with speed stir Dolphin Nautilus Pool Cleaner (2015)
    38,267
    Re: Maintaining BBB on vacation
    Ideally, have a friend add some bleach for you.
    Absent of that, raise the FC to shock level, cover the pool, hope you have FC left when you get back. Or you can float a few pucks if your CYA level can handle it.
    I always try to keep my CYA on the low side, so I can use pucks when I'm away or won't be able to add bleach on a regular basis. A few pucks won't raise your CYA too much anyway.
    30,000 gallon vinyl pool
    Hayward DE Filter
    Hayward Super Pump
    AO Smith 1 1/2 HP Pump (27GPM)
    Polaris 380 Pool Cleaner
    Check out the app I created to control my pool equipment from my smartphone:
    i-created-an-app-to-control-pool-equipment-with-smartphone-t61606-20.html
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Quote Originally Posted by kodiak1120 View Post
    Same here. I stuff the floater with pucks, raise the water level a few inches to allow for evaporation, and go.
    Mar 2015
    Elkton, Maryland
    124
    Very good, our CYA is pretty low. I will keep it closer to 30-40 once the slam is over then in anticipation for vacations. Thanks!
    22,544
    I just leave the main and injection pumps on their set schedule and make sure there's enough bleach in the drum to last while we're away.
