Thread: CYA?
    Jun 2014
    Downsville, LA.
    18
    CYA?
    Does rain or adding water to your pool mess with your CYA? Also, can I use pucks or Evolve (from the laundry isle) instead of buying a whole thing of stabilizer from the pool section if I needed to raise it just a little?
    24x52 Intex, 1hp pump & sand filter, taylor K-1004
    Downsville, LA
    38,370
    Re: CYA?
    CYA will only lower significantly if you physically remove water from the pool. If you get a lot of rain and then have to pump out of the pool, that will lower the CYA some.
    Evolve appears to by Dichlor plus some other things (citric acid and soda ash) so it would technically raise the CYA, although I would have to think that trichlor tablets (which dissolve slower) would be cheaper. If you understand all the effects of these products, then they are fine to use.
    Jun 2014
    Downsville, LA.
    18
    Re: CYA?
    Thanks!
    Downsville, LA
