Results 1 to 9 of 9
Thread: What do I need?!
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Question What do I need?!
    I bought a house last year with a AGP (listed below). It needs the new liner put in which I am going to do in a few weeks along with hooking up the new pump and filter.
    I have ZERO chemicals, after reading on here a lot I am probably going to do the bleach thing like everyone else.
    But I want to know what else I need and what do I do after filling the pool for the first time.
    Thanks!
    _______________________________________________________
    Lomart 18x52 AGP
    Hayward S210T w/Hayward 1hp Power-Flo Matrix Pump 2-Speed
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: What do I need?!
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    I've read through all that. Doesn't tell me what I need to buy and have ready.
    Lomart 18x48 AGP 7000Gal
    TF-100 w/Speedstir!
    38,260
    Sure it does. Based on the test results of your fill water and knowing the target levels ... PoolMath tells you exactly what you need.
    Without test results, all we really know you will need is stabilizer (CYA) and bleach.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    For equipment:
    A test kit
    A pole
    A brush head
    A leaf skimmer
    A vacuum setup. If your new filter setup includes a skimmer, then at bare minimum a hose and a vacuum head. Don't ask me for advice about any other types, since that's all I have personal experience with.
    A measuring cup of some sort
    For Chemistry:
    A test kit (detect a pattern?)
    Bleach. Don't bother stockpiling a bunch, because it degrades with time and temperature. You may end up with jugs of some very expensive water if it sits too long.
    Stabilizer aka CYA. How much is easy to figure. Just plug your pool size into poolmath and let it calculate the volume. Thenn use that at the top and see how much CYA you need to get from zero (tap water) to 50.
    Depending on your fill water you will need either acid or Borax or washing soda to fix PH, and maybe Baking Soda. The only way to know for sure is to test it.
    For now, content yourself with shopping for equipment and determining which stores in your area have the best prices and who actually stocks the stuff you might need. Then you won't be rushing around frantically once the pool is full.
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Exactly what I needed. Thank you Richard320!
    TF-100 w/Speedstir!
    DFW, TX
    24,468
    Hey, I just found a handy new information packed article in pool school. Recommended Pool Chemicals.
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    I saw that, Thanks!
    This also was very helpful http://www.troublefreepool.com/threa...-for-Beginners
    TF-100 w/Speedstir!
    DFW, TX
    24,468
    good one, added to my tool box.
