Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Cast Stone
    Jun 2013
    Huffman Tx
    190
    Cast Stone
    I needed a custom cap stone for my fountain 8' circle . The price was almost a grand . So I am making my own with foam and a cement shell like effis or stucco ... 1st cut rigid insulation board
    2nd shape and apply Lath
    I am going to have to learn how store these pics
    FYI This is Koi pond not a pool
    Note: the Fish scale tile job
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Cast Stone
    I love seeing someone take a project like that on. can't wait to see your results!
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Cast Stone
    That is awesome!
    Jun 2013
    Huffman Tx
    190
    Re: Cast Stone
    It will look like a poured in place counter top ,except not as strong . Not as much work
    Jun 2013
    Huffman Tx
    190
    Re: Cast Stone
    testing picture bucket
    got it now
    Jan 2013
    Friendswood, TX
    320
    Re: Cast Stone
    Man that looks cool!!
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    Jun 2013
    Huffman Tx
    190
    Re: Cast Stone
    I have to finish these by next Sat. so making it quick Scratch coat
    Test fit
    Looks good, need another few coats
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,592
    Re: Cast Stone
    That is neat! I love the sides!
    Kim
    Jun 2013
    Huffman Tx
    190
    Re: Cast Stone
    All 4 pieces are made with 2 coats . I will start the finish coat today.
    I noticed as the pieces get heavier. the joint I cut in the middle of each piece becomes a weak point and they could break in two if I am not careful
    Jan 2013
    Friendswood, TX
    320
    Re: Cast Stone
    Is the concrete strong enough you could sit on one when installed or would you smash it?
    ~Paul
    Jun 2013
    Huffman Tx
    190
    Re: Cast Stone
    you could sit on . But not hit with a hammer
    Jun 2013
    Huffman Tx
    190
    Re: Cast Stone
    1st one with 1st coat stucco
    Jun 2013
    Huffman Tx
    190
    Re: Cast Stone
    If you wanted it to be durable . For sitting, I would add a layer of cement board, but I was going for cheap and quick
    This stucco is a rough surface . But it helps hides the imperfections
    Jun 2012
    Escondido, CA.
    42
    Re: Cast Stone
    So let me get this right.. you cut the foam.. then covered it with a wire/cement shell..
    Thats too cool!
    Escondido Ca [*]~23000 gallon plaster pool built in the 70's[*]Pentair VF Pump running 10hrs at 1800rpm getting and estimated 35-40 GPM thruput[*]Sta-Rite Cartridge filter
    Jun 2013
    Huffman Tx
    190
    Re: Cast Stone
    Yes 2" iso board . Not wire ,but fiberglass reinforcing tape
    Jun 2012
    Escondido, CA.
    42
    Re: Cast Stone
    Quote Originally Posted by vinper View Post
    Wow.. looks great.. and its stable and not flimsy... Great idea
    Jun 2013
    Huffman Tx
    190
    Re: Cast Stone
    Its solid as a rock , But if I jumped on it , it would crack
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    Re: Cast Stone
    Awesome!
    Modern Geometric-ish Social Pool (4'-5'-4') ~13' x 47'. Sun shelf. Perimeter overflow spa. RiverFlow Swimjet. Dog ramp. "Bubble Lounge"
    Link to my patio build, completed 2013
    Link to my pool build, Aug '15 - Sep '16
    Jun 2013
    Huffman Tx
    190
    Re: Cast Stone
    Here is how it turned out ,
    Its not secured yet , just test fit
  20. Back To Top    #20
    Jun 2013
    Huffman Tx
    190
    Re: Cast Stone
    fish
