Results 1 to 12 of 12
Thread: Hardi or Durock and a few other questions
    Jan 2015
    San Jose, CA
    237
    went to buy my materials today I got everything to start but stopped when I went to the cement board selection. Decided to come back for it after I talk to you guys.
    I'll be using 1/4" for the side and 1/2 for the counter.
    Comparing the two, Durockwent appears to be stiffer and would resist from moister and less likely to cave.
    But mainly, Durock is more of a cement texture which leads me to think it's a better product to use on the side for a stucco application directly on the board.
    I plan on using a hopper to spray stucco on the board, do I trowel a thin layer first then spray? I'm hopping to achieve a smooth stucco texture
    do you rip your Trex board in half or use the full 5" width?
    And one last question, for the counter top, do you add braces every 16" like the frame and put the hardi/durock board directly over with no plywood underneath?
    SF Bay
    ********20,000 gallon IG Fiberglass, DE Filter, Hayward Max-Flo VS, Taylor TF-100 Test, Circupool RJ-45********
    Jan 2013
    Friendswood, TX
    320
    Re: Hardi or Durock and a few other questions
    To do the stucco you should do a brown coat and then a top coat. If it was me I would do a lathe, brown, top coat and consider (depending on how wet the area is) a redgaurd treatment underneath. I don't think the stucco with care which board. Should stick fine to either.
    I ripped mine to the width of my frame material. It's expensive stuff and no real reasons to have it overhang unless you have a finished interior floor.
    What is your countertop material? If slab then you may not need anything. If tile, I would do 16" oc and then 1/2 hardi. If concrete, 12" oc with 1/2" hardi. I wouldn't introduce plywood as it may rot and will be close to a heat source.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    Jan 2015
    San Jose, CA
    237
    I'll be using tile on the counter top, what I've been stressing out about it is the corner, there isn't much selection of bullnose 3x12 tiles for the edges. The granite labor alone is 200 per slab plus the cut out so about 600 just for labor.
    SF Bay
    Jan 2013
    Friendswood, TX
    320
    Any thought to concrete? I did a pour in place and used edging like this http://www.expressions-ltd.com/Concr...ers_s/1836.htm. Sanded and acid stained then sealed.
    ~Paul
    Jan 2015
    San Jose, CA
    237
    I did thought about it, but by the time you add all the buffing pads etc... The cost will be close to granite. I have all the tiling tools, using cheap tiles I budget about 200 for tile materials. Covering the same area with concrete would be about twice as much. 2 slab of low grade granite can be had for 120 each but the labor kills it. I have the tools to cut granite as well, I just don't have the bit to create the bullnose for the 5ft of bullnose on the L shape.
    SF Bay
    cwescapexlt4x4's Avatar
    Jul 2014
    Litchfield Park, AZ (PHX metro area)
    461
    I used 1/2 durock for the top/flat surfaces, 1/4 for the sides. I did seal mine but in AZ was probably an overkill.
    2+ coats of the stucco, scratch coat and then finish coat(s).
    I used granite tile & granite bull-nose for the top and top edge.
    Chris - aka cwescapexlt4x4
    (Build 8/26/14 - 10/17/14) in-ground Presidential Pools 15K gallon salt water pool Pentair Inteiliflo pump, Regal Blue Pebble, Clean & Clear filter, in-floor cleaning,
    LED light, 3' sheer spill, 2 benches, large Baja step. / Pergola by Booth Built 19W x 14D // Outdoor Kitchen, W/Primo grill and BBQ Coach kit for the island.
    Jan 2015
    San Jose, CA
    237
    Spent many hours figuring out the size and I think I finally got it to satisfactory.
    Had a discussion with the boss lady last night, we both agreed the grout lines of tile counter tops getting dirty is inevitable. So we're going to up the budget to fit granite slabs in the budget given that I perform the work myself. I'll farm out the 5ft of bullnose on the unfinish side at $25/ft. bbq counter final.jpgbbq frame final.jpgbbq frame final side.jpg
    SF Bay
    Jul 2014
    461
    You will probably need some supports under that long counter run.
    Jan 2015
    San Jose, CA
    237
    Quote Originally Posted by cwescapexlt4x4 View Post
    yah, I'm brainstorming that part at the moment. original plan was to use tile, then I would just frame it out with steel and back it with 3x2 inside the studs. Now that I do granite, I have to figure out what I'm going to do to support that. 1/2 square tubs are actually .625" only option is a round tub screwed into the frame extended out 8" of the 12" overhang.
    btw: this guy only has two post support the length of the over hang. The 1st photo doesn't have it but the actual frame drawing has it. Do u think that'
    SF Bay
    Jan 2015
    San Jose, CA
    237
    i think I found a solution. 1/4 steel plates under 1/4 backer board on that side of the island. stucco over it and I'm done.
    http://www.homedepot.com/p/Crown-Bol...2260/202183528
    SF Bay
    Jul 2014
    461
    Better to be safe than sorry, the extra steel will certainly help and i'd be inclined to put 2 spaced out between the ends
    Jan 2013
    Friendswood, TX
    320
    My kitchen island is 13' long and made of 2 slabs of granite the overhang is 16" or so. It is supported at 4 points. Both ends and two equidistant in the middle.
    ~Paul
