Thread: Cleaning Drain
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Cleaning Drain
    I have 2 drains that look like this. Anyone have any tips on how to clean out the junk that gets stuck between the ribs? I've run my 4WD over it about 10 times and gets about half. Brushing won't budge the stuff (probably mostly small oak nuts). Other than waiting for water to warm and diving down with a screw driver (my normal method).
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Cleaning Drain
    Yea, those are the kind of projects I take on when the water is warmer. Time to test my SCUBA gear.
    Support the site
