Thread: Recommended CYA level?
    SunnyBama's Avatar
    Feb 2015
    Birmingham, Alabama
    21
    Hi everyone! I'm opening my pool and need a suggestion about the CYA level. Here are my current test results:
    FC 0
    CC 0.5
    TC 0.5
    pH 7.5
    TA 90
    CH 125
    CYA 0
    I know I need to SLAM (the water is a murky brownish/greenish color), and I need to add CYA, but at what level should the CYA be? I'm not running the SWCG until I get the pool cleared up; I've also got my AquaBot cleaning up what I didn't fish out earlier.
    Intex Ultra Frame 20'x52" pool (10,600 gallons); Sand filter (Model SF80110); Krystal Clear SWG (Model CS8110); AquaBot PoolRover Jr. Pool Cleaner; TF-100 Test Kit with SpeedStir
    38,546
    Re: Recommended CYA level?
    30ppm is a good target for during the SLAM process. Then raise it to 70-80ppm afterward for the SWG.
    SunnyBama's Avatar
    Feb 2015
    Birmingham, Alabama
    21
    OK, I'll add CYA for 30ppm and get started on the SLAM. *crossing fingers* Wish me luck!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Welcome to TFP! Here is a link to the Recommended Levels for your pool.
