Results 1 to 11 of 11
Thread: How do you keep the solar cover on?
    May 2013
    Souderton, PA
    104
    We opened our pool early this year because our winter cover, which we had wired all the way around the pool and then weighted down with milk jugs partially blew off in a wind storm a few weeks ago. Water was in the upper 50,s at that time so we decided to open it and put the solar cover on and start testing the pool again. The winter cover was supposed to be for a 30 foot round pool but I think it was only 31 or 32 feet total and it just did not want to stay on all winter. The water is totally clear.
    Up until now we have never really had any trouble keeping our solar cover on. This week I got in the pool and got all the leaves that had blown in from the previous windstorm up and thought that I was ready to go. Last few nights have been on the chilly side and this afternoon another cold front blew through and the solar cover, which we had cut down on one side to a half and then the other side to two quarters to make it easier to manage, blew part way off. Since we have put it on it keeps blowing the cover either partially off or having one of the quarters slide under the other. (By the way, if I were to do it again I would cut it into two halves. The quarters are smaller to handle for such a big cover but they seem to present more problems). Any ideas how to keep the solar cover from having ends blow up and fold over or move under each other would be greatly appreciated.
    30 ft. round Aqua Leader agp with dished out center 23,800 gallons; 1.5 hp Hayward pro matrix pump; Hayward EC50 DE filter; solar panels; solar cover
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    Re: How do you keep the solar cover on?
    Never had that problem but maybe consider putting the winter cover on when the storms are going to hit. Maybe it would be heavy enough to keep "stuff" out of the pool.
    I hope someone soon will help out with a solution.
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    We get crazy winds at my house. I don't have the cover on right now since I am doing a SLAM. I have put the cover over the solar cover.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I have also used clamps to attach it to the top rails before too.
    Lisa
    Casey's Avatar
    SW PA
    10,444
    I can't believe you were in your pool wiggledog. It's cold! lol
    Orlando, FL
    690
    My cover does not overlap the top rail. It lays flat on top of the water and therfore, never blows off. My cover is cut into three long sections and it works great. When I get a new cover, I will cut it the same way.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Mine does not either. But I have pulled it to the side enough to clamp it so I don't find it across the yard.
    Lisa
    Orlando, FL
    690
    Quote Originally Posted by Azgirl71 View Post
    And I thought I hated windy days in Florida. I forget I'm a wind novice compared to what you get in AZ.
    May 2013
    Souderton, PA
    104
    Well, we have another windy day today and I was just about to go out now and flip the portion of the cover that had flipped up in the wind back down but lo and behold the wind shifted and it flipped it for me. Thanks for all the suggestions.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by f3justusc View Post
    Yes our winds are crazy! Last year we had winds as high as 70 mph
    Lisa
    Apr 2014
    FOUR cORNERS
    111
    that's what we do, bought clamps at H/D, several of them and clamp to side, works for us.
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
