Thread: Pump don't get enough water
    Sep 2013
    Charlotte, NC
    41
    Hi everyone,
    Last year was my first year of being a pool owner and this site has been awesome. Thanks for all you do.
    I started Slamming my pool Sunday and I have made great progress until today.
    I have an issue with high psi on the filter, but I thought was because all the gunk in the water so I have been backwashing twice a day, and I know the filter is working because I can see the progress in the water.
    I wish I knew how to post pics.
    Anyways, now aduring backwash it looks like the pump is not pulling enough water to the point that the basket in the pump goes dry and after a few seconds 30 or so water gets in it and goes dry again.
    I have made sure that the lid is put on tight and nice, skimmer basket is clean, but don't know what to do now.
    TIA for your help.
    26K gallons, IG vinyl, Pentair 1.5 HP, Hayward DE filter, TF 100 test kit, Ecojet Turbo Cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Pump don't get enough water
    It sounds like low water level or the skimmer door is sticking. It surges, correct? It starts to work, primes, and then abruptly stops working and does it over and over every 30 seconds or so? You're just sucking air. Make sure the Weir (door) isn't stuck on something and add water to the pool to get it up halfway up the skimmer opening. One or the other should cure the surging.
    Sep 2013
    Charlotte, NC
    41
    In deed the foam on the little door broke and was stuck.
    And added more water to the pool.
    Thanks for your help.
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by Stars26 View Post
    I appreciate hearing that the problem was solved. Too often we answer questions and never hear which solution actually fixed the problem.
    Sep 2013
    Charlotte, NC
    41
    I just got home that's why it took a while, I went back to look at the skimmer this morning and left the water hose open this morning.
    Thanks for your help, I greatly appreciate it.
