Results 1 to 8 of 8
Thread: Can't find guide for Opening a quick-set pool?
    georgiadawg's Avatar
    Jul 2014
    Eastanollee GA
    93
    Question Can't find guide for Opening a quick-set pool?
    Hi, Last summer was my first year owning a pool. I remember coming across a method for initial set up for vinyl quick-set pools. I have searched, but can't seem to find it again. It was a detailed guide about filling, when and how much bleach to add to start with, etc. Basically, it was a guide for preventive set-up as you are filling the pool.
    Can anyone direct me to that info? Thanks!
    Lisa
    Northeast Georgia Pro Series above ground circular metal frame set pool 22' x 52". 11,400 gal capacity. w/ Skimmer plus 2000 pump/filter. Cartridge filter (Type C)
    Intex Krystal Clear Saltwater System Model CS8110
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Can't find guide for Opening a quick-set pool?
    Support the site
    Jul 2014
    Eastanollee GA
    93
    No. I looked at that. That isn't it. It was something that gave specific steps in filling to prevent a lot of problems to start with. It talked about filling 'x' amount, then adding 'x' amount of bleach, etc. It was a step-by-step method to fill quick set pools in such a manner that headed off the need to SLAM later.
    Lisa
    38,364
    I think that was changed to what was linked to above. It is the same idea. All you need to do to prevent a SLAM is maintain adequate FC and that is done through frequent testing and dosing.
    Jul 2014
    Eastanollee GA
    93
    No, that's not it.
    Lisa
    38,364
    I said, the article was changed ... but if you know the forum better than me, feel free to find it and point it out
    If you understand the chemistry, you should not need a step by step guide. And if you do not understand it, then it is better to ask questions and learn.
    Jul 2014
    Eastanollee GA
    93
    yeah thanks for your help....
    Lisa
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Here are some handy links for maintaining your pool TFPC-style.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Recommended Pool Chemicals
    Recommended Levels
    PoolMath
    If you have any questions please ask, we're glad to help.
