Thread: Leak out of the return line
    Herndon, Va
    65
    I have determined that I have a leak going to on of my return lines. I haven't dug them up yet and before I do I wanted to get a little understanding as to what is under the ground.
    My pool has one valve for the returns. Once side goes to the return at the center of the pool and the other goes to two returns on the far end of the pool. My question is why did they split the return at the end of the pool only to put two small returns next to each other, they are only a few inches apart? The other question I have is when they split a line where do they usually split it? Would it be near the pump, pool or just about anywhere?
    Thanks for the help,
    Jim
    ____________________________________________________________ _____
    IG 25,000 gallon concrete painted pool,
    KDI American Products Model# 583090 Titan SS Vertical Grid 48sq ft DE filter
    38,524
    Re: Leak out of the return line
    If they are right by each other (not sure why), then the pipe likely splits very near the pool.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,198
    Are the two small returns on a swim out seat of some sort? Could they be aeration/hydrotherapy jets?
    As to the piping location, stand by your equipment and look at the pool. If you had a shovel in your hand what would be the easiest way to dig a trench to the pool.
    Support the site
    Herndon, Va
    65
    Quote Originally Posted by tim5055 View Post
    The two returns are located by the wedding cake.
    Looks like I will probably just start digging right where the pipes come out of the ground and hope I find the leak before I make it all the way to the end.
    Do most pools use ~1inch holes for the returns?
    I'm thinking if I have to dig up the whole pipe I might want to change things to be a little more efficient.
    Thoughts?
    Thanks for the responses.
    Herndon, Va
    65
    Did some more troubleshooting and found that my multiport valve is leaking out the backwash side. It was really hard to tell if anything was moving by the eyeglass. I have a valve on the backwash side that I shut but never saw any water coming out of there either. I guess it was small enough that you couldn't tell, but it sure adds up.
    Thanks for the help.
    Jim
