Thread: Best options for replacing Coping on Fiberglass side pool
    Apr 2015
    Croswell, MI
    1
    I have a 40+ year old fiberglass side pool with a gunite bottom. Several years ago we had a company that came in and spray coated the entire pool with a fiberglass chop gun. The concrete coping is now really starting to look bad. It has many pits and a few cracks that are developing. Any suggestions on what/how to replace it? Pool is in a northern state (Michigan). Tried a couple local pool companies and they are not into major work like this.
    Thanks.
    acgibson's Avatar
    Aug 2014
    Olney / IL
    61
    Re: Best options for replacing Coping on Fiberglass side pool
    might be best to post pictures so the pros here can see what you are talking about.
    18,900gal Viking 16'x40' Fiberglass In-Ground Pool w/ Cover Pool Auto Cover.
    WhisperFlo WF-24; Clean & Clear RP 150 Cartridge Filter; UltraTemp Heat Pump; IntelliChlor IC40 w/ IntelliPh Acid Pump;
    Easytouch Panel w/Screen Logic. Kreepy Krauly 820 Robot.
    LaMotte WaterLink Mobile Spin Lab & TF100/K2006 w/ Speed Stir.
