Thread: Have to have a booster pump?
    Apr 2015
    Flower Mound, TX
    11
    Jason,
    I am looking at replacing my setup which sounds identical to Sunandsky. I have a 1HPmotor and a 3/4HP booster pump running a Polaris.
    I saw your comment on how if you have a cleaner designed for a booster pump you have to have a booster pump. If I switch my setup to a 2speed or VS do I still have to use the booster pump?
    Can I still run my polaris on a 2speed/VS pump or am I married to a booster pump as long as I have a Polaris
    Re: Have to have a booster pump?
    If you want to continue to use your existing pool cleaner, you will need to continue using a booster pump. Your existing booster pump will continue to work with a new variable speed pump. There are other kinds of cleaners that are designed to work without a booster pump, including ones sold by Polaris. You might consider switching to one of those.
