Thread: Should I purchase a new pump?
    Aug 2014
    East Northport, NY
    155
    Thinking about set up for this season and have a friend that is an electrician doing the wiring etc of the SWG and I was wondering if I should bite the bullet and buy one of these intermittent pumps. There is nothing wrong with the workhorse I have now that is 16 years old (came with the house when we bought it) and was rebuilt 1x (not by me - prior owner).
    Typically, I would set the pump to go on at like 10:00 AM and have it shut around 5:00 PM because my thinking was since the sun is on the pool, the pump needs to be circulating water. So now, since my SWG is new, should I get one of these pumps? Not sure. My timer is one of those traditional dial ones with the pins that I will probably go digital when the SWG is installed.
    Appreciate the input.
    IG Vinyl -30,000 (20x40)
    Hayward Pro Grid DE Filter/Hayward rebuilt 1 HP Pump
    AutoPilot DIG-220 RC52 SWCG
    TF-100 Test Kit
    Aquabot Bravo
    Re: Should I purchase a new pump?
    There is not normally any good reason to replace a working pump. Unless your electric rates are very very high, unlikely in NY, you will never pay back the up front costs of replacing a working pump. Now if the pump were to fail, getting a more energy efficient pump would be a great idea.
    By the by, it is very unlikely that you need to run the pump for that long each day. Sun shining on the pool is not a reason to run the pump. For many pools, four hours a day is plenty of run time.
    Feb 2014
    Upstate, NY
    390
    I'm no expert here but I can offer some advice. When you say intermittent pump, are you referring to a variable speed pump ?? If yes, I have one and absolutely love it. Having said that, if your pump is running fine and performing as it should, I see no reason to replace it. You will have to dial in the SWG and pump run time to achieve the desired FC. This may take a few adjustments to get it where you want it. Just my thoughts.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Aug 2014
    East Northport, NY
    155
    Much appreciated. Actually the inquiry was addressed by both of you for the different things I was thinking. 1) I have no idea how long I will need to run the pump with the SWG (I will of course come here for guidance) and yes I was speaking about Variable but I agree if ain't broke, don't fix it until I have to.
    Thanks!
    TF-100 Test Kit
    Aquabot Bravo
