Thread: The exciting world of borates
    Apr 2014
    Phoenix, AZ
    52
    Just looking for confirmation on my numbers before I take the plunge into the exciting world of borates. My pool is 19,000 gallons. I'm planning on ordering boric acid from DudaDiesel.com. PoolMath tells me I need 45lbs of boric acid to go from zero to 50 ppm of borates.
    This is what I want, correct?
    Granular Boric Acid, 55 lb
    Granular Form / White Crystals
    99.9+% Pure - Technical/Industrial Grade
    Also to confirm, if I use this, I don't need to combine muriatic acid...I just need to dump in the boric acid and then confirm my pH is still in the neighborhood it should be, correct?
    19K PebbleTec in-ground with spa, Hayward Super II pump, DE 60 series filter, T-15 SWG
    Water feature, Hayward Northstar pump
    Mar 2015
    Georgia
    157
    Re: So you want to add borates to your pool--Why and How
    Yep. 45.3125 lbs of Boric Acid. Boric acid is slightly acidic so you dont need to add any muriatic acid. Your pH will likely go from 7.6 to about 7.3 if its as pure as it states just to give you an idea.
    16k AG Vinyl Sand Filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    +1 good to go and no muriatic acid needed when using boric acid.
    Apr 2014
    Phoenix, AZ
    52
    Re: The exciting world of borates
    Excellent. Thanks!
