Results 1 to 12 of 12
Thread: Heater wiring, no control, pentair intelliflo
    May 2013
    Dallas area
    85
    Hello - I have a pool only, no spa. I have a Pentair intellifo, swg, intermatic timer pf1202t, and a booter pump for a cleaner. How would I wire in a gas heater? I know it should turn off 20 min before the pump and this could work with the firemans switch and the pf1202 but the pf1202 does not control the pump. The pump controls itself.
    What are my options?
    Anthony
    Dallas area, free form, quartz finish, flagstone, pentair cartridge, vs pump, swg
    Re: Heater wiring, no control, pentair intelliflo
    The best approach is to install a current controlled relay, that only powers up the heater when the pump is drawing current, i.e. running.
    May 2013
    Dallas area
    85
    Hello Jason - Thank you. I can do that, I have one for my acid pump. Might even be able to run both off the same switch. With this option I will not have the heater turn off 20 minutes before the pump. Does this matter?
    Anthony
    Most, but not all, heaters are fine with going off at the same time as the pump. Check your heater manual to be sure if yours requires a fireman switch or not.
    May 2013
    Dallas area
    85
    Thanks again - I was planning on buying a Pentair only because I have all other Pentair products and have been happy with them. The unit's instruction manual states the following.
    "The filter pump should run continuously when the heater is on, and for at least 5 minutes after the heater turns off. Any switches in the pump circuit (including circuit breakers) that can disconnect the pump must also disconnect the heater."
    So, it looks like my options are to find another heater or get a control that can handle the heater and the Intelliflo. I will look at Hayward later today. Would something as simple as the Suntouch work? If I am going to get a control, I might as well add the cleaner pump and the SWG to it. Maybe even the light.
    Any thoughts?
    Anthony
    Any of the automation systems will take care of this for you.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    I know that the pump has its own timer and it is nice to use what you paid for, however, think about this. The pumps internal timer has the ability to recover from a power outage. A mechanical timer (that controls your cleaner booster pump?) does not. Having those two pumps synced is critical for the well being of the cleaner pump seal. A power outage at just the right time for just the right length of time can leave that seal vulnerable to a "running dry" situation. That current controlled relay sounds like a good idea, but would that work in this situation? If it did, im sure it can only protect the pump from coming on. Resetting the timers would still need to be addressed (by a human) after the power loss, and if you were on vacation....
    What we do is just run both the filter pump and cleaner with mechanical timers, or some sort of automation, and disable the internal timer. It was a good idea for the manufactures to integrate timers into their software. It appears that they just didn't consider the power outage scenario with another pump. The important thing (I think) is to have both the pumps controlled by the same type of timer.
    Factory Warranty Station for:
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    I can not think of a heater today that still required a fireman switch. This was necessary when most used a fire tile inside the heater that remained hot when the heater shut down and could melt piping down stream. Most major heaters today use a file tile that is cool when the heater shuts off, eliminating the need for the fireman switch. Since you have a Pentair VS pump you are looking for a controller it would be easier to connect with a Pentair controller. Just make sure it will control the pump.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Dec 2014
    Riverside California
    482
    How about the current Raypac 2100 series. I just had a 400 Btu low Lox installed. About to install Easy Touch controller. What if any cool down should I set?
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Oct 2014
    Elizabeth
    426
    Look at the manual, I doubt that the RayPak needs any cool down.
    Hayward Pool Tech
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Quote Originally Posted by gary300 View Post
    Raypak's are very forgiving. But if you feel more comfortable having a cool down configured, 5 to 10 minutes should be fine. These units cool down pretty fast.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Raypaks' Capron header was designed for just this kind of problem, but i have still seen them melt the unions, especially after a spa heating cycle, where the internal temps are higher than say heating the pool. A delay or firemans switch is a good idea if for nothing else but piece of mind.
    Easytouch has a delay built in to it. No extra setting needed.
