Thread: Is there a need to test for CC or TC?
    Sep 2011
    So Cal
    155
    I read the instruction that came with the kit (TF-50) and did the CH test. The instruction did not say to swirl after each drop when add the R0012. At one point, the lower portion turned purple but the top was still red and I kept adding until the whole thing turned to purple and then blue. That was 40 drops of R0012. I decided to swirl after each drop of R0012, it only took 30 drops. I didn't know I was supposed to swirl for each drop of R0012 until I read the instruction here. If it makes such difference I wonder how the instruction of the kit missed it. Before I started swirling, I re-read the instruction several time but it sure didn't mention to.
    My question is why it there a need to test for CC or TC if you know your FC?
    Thx
    35k Gallon, 2 In Piping, Aquarite, KK, Spa, Water Fall.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Extended Test Kit Directions
    Here is a handy link to some videos on testing that might be helpful
    https://www.youtube.com/user/tf100te...e=results_main
    I will let someone else explain CC, TC and FC a little better than I can.
    38,532
    Because high CC are an indication of a problem: ABCs of Water Chemistry
    Sep 2011
    So Cal
    155
    I see. Thx. Sorry for the basic questions. I guess I didn't click on the "Read More..." in the Pool School's Chemistry section. That video is quite helpful. Thx. "keep adding until color stops changing" was very instructive. The instruction should have said that. And I guess with Tf-50, it uses less amount of solution.
