Thread: Tail end of the SLAM process directions
    Mar 2015
    Bossier City, LA
    13
    So I took the pool from green swamp with very little debris to almost all the way clear. This is where I think I'm lacking direction.
    Slammed at 22.0 FC for 4 days. Its now getting clearer by the hour.
    So, My questions is at what point is it safe to let the FC drop to the suggested levels of 4-5 with a CYA of 45?
    Plaster pool
    Bleach for Chlorine.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Tail end of the SLAM process directions
    Welcome to TFP!
    You are done with the SLAM when:
    1. CC is 0.5 or lower;
    2. You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    3. And the water is clear.
    When all three are true, you are done SLAMing and can allow the FC to drift down to normal levels. For more complete information on the SLAM Process, click this link: SLAM
    Another handy reference when SLAMming and for ongoing maintenance of the proper level of FC: FC/CYA Chart
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Welcome!
    You're no doubt testing FC & CC every few hours. If you time things right, you'll do your last test of the evening after the sun sets, and the first in the morning before the sun hits, and you'll know when you passed the overnight loss and CC tests. "The water is clear" test is more subjective, but if you have passed the other two and the water isn't cloudy immediately after brushing, then you're done.
    Mar 2015
    Bossier City, LA
    13
    Sounds good. I forgot to write that my CC is 0.5. I'm not understanding the relationship between CC and FC. How do you manipulate one without affecting the other?
    16,000 gallons. Gunite/Plaster. BBBM method. Sand filter. Polaris "Sputnik" cleaner tank.
    Mar 2015
    Baton Rouge, Louisiana
    19
    FC= Free Chlorine (Unused)- When you add Chlorine to your pool it is available to be used as a disinfectant
    CC- When your FC attacks stuff in your pool it becomes CC which is no longer able to be used as a disinfectant
    CC are actually what causes the Chlorine smell, and hurts your eyes. More FC (unused) gets rid of CC, and once you have a good level of FC there will be nothing left to kill!
    (That's my newbie understanding anyways)
    44,000 gallon IG vinyl liner pool. 1.5 hp single speed motor on E Z flow pump/sand filter. Unknown age of pool, Kreepy krauly vacuum, Taylor K-2006 Test Kit.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    That's pretty good! Here is more info. ABC's of Pool Water Chemistry
