Results 1 to 9 of 9
Thread: Switched to Bleach and now adding acid daily
    Apr 2015
    TX
    32
    So I finally got my CYA down and switched to a Stenner injection pump for bleach instead of Tri-Chlor pucks.
    The pump is working like a charm and keeping my FC at about 5. But now I am having to add about 16 oz of muriatic acid daily. Was hoping to not have to add chemical everyday. Is there something I can do? Last year using the Tri-Chlor pucs, my Ph was super constant. Now it creeps up to 7.8 to 8.0 seemingly every day.
    BTW, my TA seems to be about 120.
    14,800 gallons in-ground vinyl. sand filter. 1.5 hp pump
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Switched to Bleach and now adding acid daily
    You have your CYA down to what ??
    How about a full set of results
    Solar Blanket, Well Water, Borax Added. 68
    38,475
    Well the high TA is likely most of your problem with the pH.
    Apr 2015
    TX
    32
    Cya = 40
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    How old is that pool? You might still be suffering from curing plaster, you just didn't know it because trichlor is very acidic.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    CYA is good. Here is a link on how to lower your TA, aim for 70-80.
    http://www.troublefreepool.com/conte...tal-alkalinity
    Here are your Recommended Levels
    Apr 2015
    TX
    32
    vinyl pool
    Looks like time for acid and aeration. Tons of PVC laying around. I might build a Franken-aerator.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Your pH stayed lower because of the pucks. Now you have to replace that acidity with something.
    Essential Links:
    Jul 2014
    near London, UK
    37
    I had real bad Ph bounce due to high TA when I first filled my pool, was adding MA twice a day to start with
    Test daily and use poolmath to calculate correct MA dose - keep a note of this and you will see that as the TA drops the MA additions get smaller and further apart, until you get to a point where the pH doesn't rise very quick.
    Just maintaining the Ph in range will lower the TA over time, repeatedly lowering Ph to 7.2 + aeration gets you there quicker. Will use the same total amount of MA either way
    Thanks to Richard320 for those tips, really helped my understanding!
    4k gal 16' oval AGP
    Mega 1/3 HP Pump + 14" sand filter
    Palintest tablet DPD/PH/ALK - wish we could get a TF100 this side of the pond!
    Lovibond CYA
