Thread: Hayward Push/Pull Value T Handle
    Jul 2014
    Phoenix, az
    3
    First let me say I've got more good information from this site since finding it last year, than in the previous 15 years of owning a pool. I've never had to ask a question, as the answer were easy to find on the site. Well that ends today, I've got a problem that I need some input on.
    I've got a Hayward DE filter with a push/pull value that the T handle and shaft have come off the plunger. The pin holds the shaft onto the plunger looks to having broken when I went to turn it. The value and filter are about 10 years old. I just replaced the o rings in the value about 2 months ago.
    My issue is getting the plunger out of the value. I've tried pulling the plunger with a pair of pliers. It just won't move at all. Short of replacing the whole value, any ideas on the best method for getting the plunger out??
    Thanks in advance.
    Ron
    Re: Hayward Push/Pull Value T Handle
    Welcome to TFP!
    On most models there is a cap covering the top of the valve that can be removed, which gives you access to the inside for replacing o-rings. If you take that off, it should be enough to let you see what is jamming the plunger.
    Jul 2014
    Phoenix, az
    3
    Jason,
    Thanks for the quick response. I was able to get the top cover off to access the top of the plunger. After playing around with it, I got it turn a little, which allowed my to pull it out. Looks like one of the O rings got hung up on one of the opens for the cross pipes. Now it's off to the local pool store for a new O ring.
    One more question. Can I use a cotter pin instead of getting retaining pin for the shaft? Asking since the hole for the retaining pin in the plunger is no longer round from use.
    If you can find a cotter pin that is sufficiently corrosion resistant that would be fine. However, most of them will rust away too quickly.
    Jul 2014
    Phoenix, az
    3
    Good point, I'll keep it in mind.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Look for something that is stainless. Would a long SS screw do it.
    chiefwej
