Results 1 to 14 of 14
Thread: Which one of the poolmath calculatars to use?
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    Should I be going by the Pool Math one or the newer one the Pool Calculator on my home computer?
    I'm getting different amounts of how much chlorine to use to shock my pool .
    The original Pool Math one says Shock is 29 and the newer one the Pool calculator says 21 form what my readings are now.
    Just curious way they say different amounts.Was the newer one updated and should I just use it now?
    I'm going to be buying the App for my smartphone when I get it.
    Getting tired of running in the house to use the desktop every time I need to add something.
    Thank you guys for all the help
    Sarge
    6100 gal. In ground pool,1HP Pentair Superflo pump, 100 sq. ft. Cartridge filter , 3" tab dispenser, Aqua-Cal heat pump system ,Baracuda MX8 cleaner, in a Birdcage,Taylor K-2006 complete FAS-DPD chlorine kit.
    "Remember Folks Freedom Isn't FREE !!!"
    38,301
    Re: Which one of the poolmath calculatars to use?
    The "new" one and the one that is supported and updated by this forum is PoolMath.
    There are no officially supported apps. Although some members have created them with matching recommended levels.
    PoolCalculator.com was sold, and is no longer being maintained. Over time it has gotten out of date with our most recent recommendations.
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    Thank again Jason, so Pool Math it is.
    and still set the suggested goal levels to TroubleFreePool.com like I have been?
    Since it's saying hotter here now I have been noticing a few spots of algae starting to form in places that is harder to brush from the deck.
    Now I can get in the water and do them I was thinking about shocking the pool since I have never done that since I moved in here this winter.
    I kicked up my FC to 11 from what I was keeping it when I had a real high CYA level in the winter then it turned hot.
    I know I still have to get my CYA down a bit more thou when I can get a chance.I'm gonna wait a while first
    I was hoping the rainy season now and water dissipation would help me out.
    So looks like more brushing more often is the deal. Or would you suggest I should just shock it once now? The water looks crystal clear still now.
    My last readings this morning after a good rain last night was:
    FC 9.5
    CC 0
    PH 7.7
    TA 70
    CH 310
    CYA 60-65
    The TA is a little on the low side
    38,301
    If you see algae, you need to follow the entire ShockLevelAndMAINTAIN Process. It is not a one time dose of chlorine.
    Your TA is fine. Your CYA is a little high, but manageable (as long as you are not using more tablets).
    Lower the pH and then start the SLAM.
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    Since I just did an overnight FC loss test on 4-16-15 and the total loss overnight was just .5 from 7.5 down to 7.0. Do you still think I need to SLAM it now?
    I was thinking the brush was using just wasn't getting in the curves of the steps and walls well enough and we had company for a few days so I wasn't doing as good of a job with the brush for a few days before I noticed the slight algae building up in them areas and the temps have been higher too Since then I have got a new and much better brush that has a super curve on the sides that works a lot better on them.
    If I need to SLAM I will but, it will have to wait a week or so for me to be here and back to normal so I can test the water regularly like I have been for the SLAM process. I have to go back to the VA hospital again here for a little while soon.
    That is the reason I didn't think I wanted to SLAM it just yet since the water looks so clean and clear all the time,but I will if I have too.I was thinking just maybe shock it for now.
    Thanks again for all the great help I get on here guys. It is much appreciated for sure.
    If there is visible algae, you need to SLAM.
    There are several criteria for SLAMing. You are not done until the water is clear, you pass the overnight test, CC is 0.5 or lower, and there is no visible algae. You need to continue until you meet all of the conditions.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,777
    Best wishes on your hospital visit. I understand why you may not want to start a slam right now, but if you can see visible algae, a SLAM is what's in order. Do you have someone available to help at least maintain a decent chlorine dosing daily while you are in the hospital? You do not want that algae to get ahead of you...
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    Jason, as I posted that my overnight FC loss was just .05 earlier. I haven't seen the algae in the corners since I got a better brush and raised my FC up to a 10 for a few days now.
    Last full test yesterday was:
    FC 9.5
    CC 0
    PH 7.7
    TA 70
    CH 310
    CYA 60-65 ?
    This morning
    FC 9.5
    PH 7.6
    Thanks Swampwoman, my wife is the only one and she will be busy visiting me and other stuff.
    She does not understand the test kit as of yet. and the poolmath
    I still got her in training on that. You wemens are hard to train... LOL
    But, she can help do the brushing for me when I get back if I have to slam it.
    If the algae is gone it sounds like you meet all of the criteria for being done.
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    I hope that is the case Jason.Like I said before I think it was just that brush I was using wasn't getting in the curves that well and we had company here too and I was kind of busy with them. I didnt notice it untill the morning they left.
    Im not saying I don't or need to SLAM it if it needs it don't get me wrong you guys know more about it than me for sure
    It's just the water looks so clear and clean all the time now since I have started coming in here and I do appreciate your advise on everything.
    Ill be working on getting the CYA down a little more too as soon as I can.
    Jul 2012
    Dallas, TX
    179
    Is there a way to use the PoolMath calculator offline? I recall a way to save the previous calculator to the Desktop in the event that Pool School - TFP Home Page site is down.
    Can this be done with the PoolMath calculator page?
    - Pool Type: 15k Gal Gunite IG non-SWG / Built 1988
    - Pump: Pentair Challenger / Sweep Pump: Letro Model LA01N .75HP Single-speed / 6 hrs-day (1 turnover)
    - D.E. Filter: OEM: Nautilus (Pentair) #NS 36 / 36 Sq Ft / D.E. Charge: 3.6 Lb
    - Pentair 4-wheel Sweep LL505G - Booster Pump runs ~2 hrs/day
    38,301
    Yes, just save off the html page.
    Jul 2012
    Dallas, TX
    179
    10-4, thanks
