Thread: Adaptor for Baracuda G3 hose
    Apr 2015
    Lancaster, Ca
    17
    Hi all. Is there an adaptor that goes from the hose of the G3 to my wall intake? I've been looking but all I can find is is the one that goes into the skimmer. The previous owner of my had wrapped electrical tape around the male end of the hose and inserted it into the wall inlet. I let it go but over the winter winter while the pool was covered it came out, the flap closed and it caused a mess with my pump. Now I know, don't leave the cleaner attached if the cover is closed.
    Thanks for the help.
    9k gallon IG rectangle plaster pool spa combo, Sta-Rite P4R6F3-188 1 1/2 hp pump with Schneider Electric AVT11HU41M2U variable speed motor drive for 2 speeds, Sta-Rite System 3 cartridge filter, Sta-Rite SR400NA gas heater, Jandy AquaLink RS, Zodiac Baracuda G3 cleaner Cover-Pools T-3 automatic cover. Built in 2006. K-2006 test kit.
    38,290
    Re: Adaptor for Baracuda G3 hose
    My cleaner came with an adapter that looks like this:
    A little ridge holds the hose in place and when the cleaner is removed it closes off the hole (lowers entrapment risk).
    Apr 2015
    Lancaster, Ca
    17
    Thank you. I I have one like that but it's too big for the hose. Maybe I just need to remove it and take it in to a couple shops around town to see if I can find a smaller one. I appreciate your response.
