Results 1 to 10 of 10
Thread: update stenner up and running
    Mar 2015
    Sugar Land , TX
    424
    https://docs.google.com/file/d/0B8fk...p=docslist_api
    Https://docs.google.com/file/d/0B8fk...p=docslist_api
    Hope pics work. Easy install once all parts gathered. Taped 1/4" in pool \ spa return line. FC for the first two days at 4 but my tester only goes to 3 so may be higher. Need a tester that goes higher ( current from PB ). Thanks to all for answering all my questions.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: update stenner up and running
    Pics didn't work. Try setting up a photo bucket account and Post the IMG links from your albums.
    If I may make a friendly suggestion to purchase one of our suggested kits. A TF100 or Taylor K2006 will get you the higher FC test that you need.
    Essential Links:
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Weird, his IMG tags look good, I can cut & past the photo locations and see them so what's up??
    OK, this looks really nice!! It should save you lots of time lugging jugS.
    Just remember, it does not eliminate the need for testing and adjusting. Your chlorine demand is going to change as the season moves along. I find myself slowly turning up the injection rate as the season progresses, then as it wanes I'm turning down the flow. I'm not sure how how handle the winters there, but as I got into winter I couldn't turn down the flow enough so for a while I cut my bleach 50/50 with water. Then in the dead of winter I just turned it off and manually adjusted.
    You will get a feel for it, but it makes life much easier.
    ****On Edit
    I missed the testing part - Patrick is right, you need to pick up one of the recommended test kits. We vote for the TF100 as it serves two purposes: Provides the Taylor reagents in the quantities most pool owners need and it supports this site. www.tftestkits.net
    Support the site
    just an fyi the img tags are incorrect. they are supposed to have a /img at the end of the image tag I believe.
    AG 24' round 15k gal
    cartridge filter 125sf
    May 2014
    Franklin, NC
    9,187
    Quote Originally Posted by rphpool View Post
    Modifying IMG tags didn't work
    Support the site
    The links link to web pages that have the images on them, not to the images themselves. I don't think it is possible to directly link to images with Google Docs.
    I changed them to urls, so at least they can be clicked on now.
    Mar 2015
    Sugar Land , TX
    424
    Thanks for fixing links Jason. UPDATE: I have been running for 9 days on Stenner now and have been bouncing from high to low chlorine depending if we are using spa or not. I have been adding 27 oz. of 8.5% once daily ( at 3am ). I think the spa demand is really eating the chlorine. So I am going to try 37 oz ( which I was adding manually before Stenner) ( when I could remember LOL ). Hopefull that will keep me at 4ppm target. CYA is at 40 by the way. It's a learning process for sure. I wonder if dividing the total dosage by 3 different injection times would help. Any thoughts?
    May 2014
    Franklin, NC
    9,187
    I have mine set to deliver chlorine anytime the pump is on. Low steady dose. If we go out at night to jump in the pool we like the waterfall, so I manually turn on the pump which in turn turns on the Stenner.
    Support the site
    Mar 2015
    Sugar Land , TX
    424
    Tim I am going to take your advice and run mine when my pump runs. I run 4 times per day , 1 1/2 hours each time, so 10 minute injection 4 times daily should keep it balanced through the day. I was still bouncing from high in morning to very low later in evening ( I was injecting at 3 am before ).
    I am curious about one thing. The 15 gallon tank I purchased for the bleach had Dr Pepper syrup in it, in it's previous life. I can still smell the Dr Pepper when I open the tank (LOL at least the pool does not smell of Dr Pepper ) . Do you think that the bleach could be combining with the Dr Pepper and make it not work as well?
    May 2014
    Franklin, NC
    9,187
    I would thnk that if there were any syrup left in the tank the bleach will oxidize it quickly. Interesting idea though.... I really like Captain Morgan & Diet Dr. Pepper, having the pool smell like that might be neat.
    Support the site
