Results 1 to 7 of 7
Thread: Any issues with Dolphin Nautilus Plus cleaner with Pebble Tec pool?
    Aug 2014
    cary
    3
    Any issues with this combination? Will it still clean/climb/etc. with no problems? Will it damage the pebbletec finish?
    Thanks
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Any issues with Dolphin Nautilus Plus cleaner with Pebble Tec pool?
    Welcome to TFP!
    I don't know the Nautilus, but I know the M5. I can promise you it will not damage the finish in your pool. Actually the other way around. While the PT finish won't damage the cleaner, it will wear out the contact points such as tracks sooner than some other finishes. I think people have had good luck with the Nautilus, and my small experience with Dolphin products has been very good.
    Essential Links:
    30,415
    Location = cary, ???? NC?
    Aug 2014
    cary
    3
    Cary, NC - yes.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Thank you! Please modify your profile with that info.
    Essential Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    The nautilus plus is new this year, so not a lot of familiarity with it yet. I did look at online though when it came out. I think the only major change was adding the handle and its a top loader. The basic cleaner part and drive is the same though.
    I have the normal nautilus, and there be no problem at all using in on your plaster. Its got a single scrubber front and back and rubber tank tracks that drive it.
    Divin Dave,
    Aug 2014
    cary
    3
    After using it for a couple months I have to say I love it. It picks up an incredible amount of stuff including fine dirt. Very happy Nautilus Plus owner.
