Results 1 to 11 of 11
Thread: Pressure question
    flyinokra's Avatar
    Apr 2015
    Hernando MS.
    20
    Pressure question
    I just changed the filter sand in my 25" filter with 300lbs of new pool filter sand. I back washed for about 5 or 6 mins and the water was nice and clear in the sight glass. I then rinsed for about 2 mins. So I then turned the pump off then to filter and turned the pump back on. I was expecting the pressure to be in the neighborhood of 12 PSI but it was 20 PSI. I changed the gauge when I changed the sand because the other one didn't work so I don't think it is the gauge. My question is is that to high or is that just where mine is going to be with clean sand?
    30K Gallon 40x20 IG vinyl liner
    1.5HP Hayward Super Pump, a 27" Hayward Pro sand filter and
    Aqua Rite T-15 SWG
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Pressure question
    did you turn it off and on a couple times? Flick the gauge with you knuckle and it still repeated at 20?
    If so, then thats prolly just where its at with the new sand.
    Divin Dave,
    flyinokra's Avatar
    Apr 2015
    Hernando MS.
    20
    Dave thats funny you should say that. I did turn it on and off a couple of times and tapped it with my screwdriver.
    Aqua Rite T-15 SWG
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    welp,
    there ya go then. The clean pressure is 20with your new sand.
    Divin Dave,
    Jul 2014
    Independence, KY
    220
    Any chance that your new sand is a smaller particle size than the old sand. Smaller grains will cause higher pressure, so that might explain it.
    IG W/Vinyl Liner Oval 18x40, 21K gal, Oval 3'-8'
    Pentair Intelliflo VS Pump, Sand Filter
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    If you original gauge was not working, how do you know the new one is inaccurate? Did you install the new gauge first, run your filter, then change your sand? My filter, after backwash, runs at 18 psi and loves 20 (that is with the old sand and new sand after I changed it). I just let her run until it gets to 25 psi or so.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    May 2013
    Long Island NY
    419
    I have had different gauges over the yrs and they all seem to have a different benchmark reading.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yea, that's just the problem. Some are better than others and none of them are extremely precise. While 20 seems a touch high, it really isn't wrong, its just what you have. But at least you know where you are. If it isn't one, a nice Glycerin filled gauge is good to have. They tend to be a bit better in terms of overall quality/accuracy.
    Essential Links:
    flyinokra's Avatar
    Apr 2015
    Hernando MS.
    20
    Thanks for the replies. It's my first pool and I'm just learning as I go.
    Aqua Rite T-15 SWG
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Well, there is no shame in that. In fact, quite the opposite.
    Glad you found the forum, and it's good to have you with us.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Yep, welcome to TFP! Flyinokra! LOL. Need to fly some okra into a fryer and onto my plate!
