Thread: new vinyl liner
    ernie01jt's Avatar
    Mar 2015
    Smithton IL
    178
    new vinyl liner
    Hi folks.
    Like it says, I'm getting a new liner this spring and am wondering where to start as far as salt and bleach since I'll have new water.
    I hit search several ways but didn't see anything close. I'm just trying to make sure I have all that I'll need on hand. Prior to this I had a service take care of the chemicals and now I plan to take the plunge(PUN INTENDED) and take care of it myself. I have a new TF100 test kit. I'm having the water trucked in, it comes from the same supply as to the house so I'm wondering If I could test the water out of the faucet giving me practice and an a base line ahead of time.
    Ernie
    18' x 38' 20,500 gallon vinyl IGP, 3.5 - 7' depth, Pentair FNS Plus DE filter,
    2hp Whisperflo high performance pump, 1.1hp boost-rite pump for the cleaner,
    250k BTU MasterTemp heater, LetroLegend pool cleaner, Hayward TurboCell GLX-CELL-15 chlorine generator
    Speedstir, K-1776, TF-100
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: new vinyl liner
    Hi Ernie,
    Certainly, test your fill water so you can get some practice, but you wont see any FC or CYA in there, so test it if you want, or not.
    TA would be good practice. CH too, but a vinyl pool really doesnt need any specific level of CH. As long as it isnt way way high, then no need to do anything with it.
    In the meantime, also play around with Pool math to get a feel of adding stuff does. Run though some scenarios and pay attention to PH and TA when adjusting (or not), those. TA and Ph go hand in hand with each other.
    As for testing the pool water. Always wait 30 minutes after adding something, and then test again.
    Always have the pump running when adding stuff.
    Always mix any powder chemicals (except for CYA) in a bucket then pour it in.
    Always pour liquid chemicals Slowly.. in front of a return... I move aroun and add stuff in front of several returns...
    Once the water is in, then adjust the pH first.
    Next, use bleach to get your FC to a level of about 4. Test it and also test for CCs.
    you will need enough CYA on hand to get you up to recommended level... but dont add all at once. Add about 2/3 by teh skimmer in the sock method then test it a few days later. Increase it if needed.
    Next, test for TA and CH. Do nothing with CH.
    let us know if you have anything specific that worries you, or would like more clarification on..
    Next add salt. Let it mix for 24 hours before turning on the SWG.
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: new vinyl liner
    Alright, we'll get you all set!
    Here is your Water Balance for SWCGs for your pool.
    Go to PoolMath to figure out how much of what to add to get you to the levels.
    Do some reading, then do some math and come back with some questions? Happy reading.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,539
    Re: new vinyl liner
    Good job getting the test kit! You are on the right track!
    Chlorine-find YOUR best source for it. For some it is walmart, others ACE Hardware, others the pool store using their jugs. Make sure to check the % when you check the prices. Walmart=8%, Pool stores = 11% on average so...
    I would go ahead and test your water from the tap. That will put you way ahead of the curve. I will tell you that do not bother testing the CYA as tap water does not have any.
    Let us know how it goes!
    Kim
