Thread: Polaris 280 scheduled run when disconnected
    robbief00's Avatar
    Dec 2014
    TX
    40
    I have a Polaris 280 set to run on an automatic schedule. If I remove it from the pool in order to swim during this time, do I need to cancel the scheduled run on my Easy Touch system? Is there any problem with letting the booster pump run and leaving the quick disconnect fitting in the wall?
    Thanks!
    My Pool Build
    15k gal IG freeform w/ attached spa, Wet Edge Luna Quartz Bermuda, 3.5' to 5.5' depth, Intelliflo VS pump, Cartridge filter, MasterTemp heater
    1 hp Whisperflo for ledge bubblers/weeping rock wall, Polaris 280, EasyTouch 8 Automation, Intellibrite 5G color LED's, TF-100 w/ Speedstir, Stenner Peristaltic Pump
    Re: Polaris 280 scheduled run when disconnected
    Welcome to TFP!
    If the booster runs while the cleaner is disconnected there will be a fairly strong jet of water coming from the cleaner connection. That jet isn't dangerous, may or may not be appreciated.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Yeah, you aren't going to like swimming around that water jet. During summer we move our pool cleaner schedule to late at night, like 2am. Or else somebody, usually me, has to go turn off the pump.
    robbief00's Avatar
    Dec 2014
    TX
    40
    Thanks for the replies.
    I removed the Polaris in the morning to prepare for a swim party that afternoon. I couldn't figure out a way to cancel the scheduled run so I just had to delete it. Seems inconvenient to have to delete and re-create the schedule each time this happens. I will just reschedule it to run early in the mornings when we are unlikely to be swimming.
    My Pool Build
