Results 1 to 7 of 7
Thread: Filling new pool with well water?
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Does anyone see any issue with filling my 25k gal pool with well water? I have a well & pump dedicated for outdoor watering and such, so it does not go through the softener. High pressure, so it would fill it over night - I think.
    I do have a high iron water content, and of course I would have to add the appropriate chemicals. I grew up on well water, so it tastes fine to me. I just don't want to have all sorts of water issues down the road.
    The other option would be to have a local fire department do it.
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Filling new pool with well water?
    Where does the Fire Department get the water? Does it have high iron? Are they getting it from a city water system or drafting it from a pond?
    It would be best to avoid having iron in the water and its issues form the start.
    Support the site
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    The fire department likely gets it from a hydrant, so the questions if that hydrant is drinkable water. If so you should be ok, but if not, as mentioned, you could be running the risk of having a high metal content right from the start.
    Any way you can test a sample before you commit, either way?
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    30,403
    If you have ENOUGH iron in your water, you would be haunted by it virtually forever.
    Depending on the concentration of iron from that well, I would suggest you should, if you can, fill from a hydrant (although they may have iron, too) and then use your refill water from the softener.
    High iron content is a constant struggle and you simply cannot effectively get rid of it.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Avoid the iron at all costs. Well, within reasonable costs. If you're on municipal as well as have a well, just fill from the municipal supply by hose. Otherwise, inquire with the local FD and ask where they pull the water. Here I know our FD pulls from the hydrant, which is basically drinking water. They ask for a minimum donation of $75 and charge the municipal rate per 1000 gallons to bring up a truck for a fill.
    If you do have municipal water and fill your pool, normally you can contact the agency responsible for billing and ask that they remove the sewage fees from the volume of water you use to fill the pool. This is the most expensive part of the water.
    Isolated Spa - 345 Gallons
    Jun 2013
    Erie pa
    68
    I had trouble with iron stains from my well water.Had to remove them with an iron remover(i think it was just ascorbic acid).then i drained the pool partially and had it refilled with trucked in water(i think it was around 400.00).now a solar blanket keeps evaporation down and rain usually keeps it topped off.
    16x32 vinyl ig with foxguard steel walls,gli liner ,hayward de filter,hayward heatpro heat pump,hayward colorlogic 4.0 led.pentair circular weir skimmers.hayward sharkvac xl robot,gli mesh cover.polk atrium speakers,sonos music system.erie pa.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Do that again. Or find another source of iron free water. You do not want this problem again.
    Essential Links:
