Results 1 to 7 of 7
Thread: Pool Heater Questions
    Jun 2012
    Glen Burnie, MD
    38
    Just purchased a pool heater for my 18' pool. Not sure on the connection, but want to use Propane due to natural gas not an option in my area..
    What size propane tank should I use? Does the tank need a regulator? Does anyone know what size of the connection within the heater?? The install manual doesn't specify the size.
    Any and all help is greatly appreciated!
    8000 Gallon 18' Round 52" Deep Morada Pool (Namco) DE Filter
    Jun 2012
    western NY
    1,560
    Re: Pool Heater Questions
    Your propane supplier will be the best one to answer the question on size, regulator, etc. As to the connection size we won't know either as we don't know what model/type of heater you have. Is the heater set up to run on propane?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2012
    Glen Burnie, MD
    38
    I have a Hayward H100ID1. The heater is set to run propane.
    Jun 2012
    western NY
    1,560
    If it is the propane model it should be 100ID"P"1 unless someone installed a conversion kit. Either way the gas valve will have a 1/2" NPT threaded port for the incoming supply
    Jun 2012
    Glen Burnie, MD
    38
    Quote Originally Posted by danpik View Post
    Your correct, it is Hayward H100IDP1. I have the propane supplier calling me for an appointment to check things out.
    I was told at the pool place that I could use a 100lb tank, bad thing is to take it somewhere and get filled would be a pain in the butt! I may just have suppliers add a tank and refill whenever needed.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    When it comes to propane and the H100 a 100lb tank is minimal. I have forgotten the gallon equivalent to 100lbs. I recommend at least a 150 gallon tank. Remember with propane as the tank goes down the amount of gas that can be used is reduced and at some point the heater will not light.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    100lbs of propane is less than 25 gallons.
