Thread: Looking for a used above ground pool - Long Island
    Jul 2013
    Long Island, NY
    534
    I'm looking for a used above ground pool. Has to be 15 feet round. That is all I have room for. I live on Long Island. Thanks!
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    Casey's Avatar
    SW PA
    10,450
    Re: Looking for a used above ground pool - Long Island
    Craig's List.
    38,371
    I agree. You should have better luck looking locally. We are more about helping maintain your pool than finding one for you
    Orlando, FL
    690
    +1 for Craigslist but be ready to spend your time at someone's house taking the pool down, transporting it, and putting it up. Also, you will most likely have to buy a new liner, which will cost 100-200+. If there is rust on the pool, you will have to fix it and possibly locate replacement parts so try and find out the manufacturer from the current owner. We can usually help with assembly questions and if you provide details, we can often give our advice on any pool you are considering.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Jan 2013
    Long Island, NY
    184
    Where on the Island are you? Try asking around at a pool store, you'll be amazed at how many customers at the pool store get so angry because they always have algae and are willing to get rid of the pool. I can't tell you how many times I have heard, "I wish I never got this stupid thing!" Or, maybe someone is there looking to upgrade to something bigger, and would be willing to let you have the old one for free, if you remove it and cart it away. Never hurts to ask... Also check the classified section in Newsday, they may have listed one in there. However, if you are only looking for an exact size 15' round, you may have to just buy it new. Besides, having someone elses hand me downs are not always bargains.
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
