Thread: Opening--What Chemistry Order
    Question Opening--What Chemistry Order
    5K gal vinyl, with cartridge filter and 2 speed pump
    Pool was very green yesterday, the bottom was almost/sorta visible. I used a gallon of 8.25% bleach and this morning the FC was 6.4% (using the good test kit &.2 ppm scale)
    Pool is still green but bottom is visible, added additional 32 oz of 8.25% bleach Will vacuum and clean cartridge later this AM.
    FC = 10 ppm
    CC=
    pH > 8 (required 8-9 drops of reagent to reduce to target level of 7.5-7.8 (that color is hard for me to read)
    TA =60 ppm
    CH = 30
    CYA = <20 (maybe zero)
    After vacuuming and filter cleaning, what do I do next, At this stage it is almost a circular equation.
    Thank you
    Re: Opening--What Chemistry Order
    First priority is to get the PH down to the 7.3 to 7.5 range. Remember not to trust the PH test results when FC is higher than 10, so do this at some moment when FC is fairly low.
    It is much simpler to SLAM if the CYA level is at least 30. I would add enough CYA to raise CYA by 30. That might overshoot 30 just a little, which is fine.
    Then it is time to SLAM the pool properly, see instructions in Pool School.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,201
    Welcome to TFP.
    Here is some info on updating your signature, What we need to know to answer your questions
    Thanks, do you recommend liquid or granular CYA?
    Mobile, AL--5K gal, 15 ft diameter, 177 sq ft surface, Vinyl AG, 2 spd 2 hp Hi-Flo motor w/ Clear Water II 200 sq ft Cartridge Filter; Laars Lite II 400k btu heater
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    8,720
    Quote Originally Posted by 7Iron View Post
    Granular will save you a ton of money. They both take a while to show up on testing.
    With the granular just pour what you need in an old sock and hang it in front of one of your returns. Shoot a little lower than your goal and make a second application later to bring it up. You don't want a math error causing you to overshoot.
    Support the site
