Thread: Need help identifying my sand filter
    Apr 2015
    Stroud, Ok
    4
    Hello Everyone,
    I am a new member to this site and this is the first year I'll be using the TFP
    method. I'm in need of some assistance. I just bought a home last year with an
    11,000 gallon in ground pool. Unsure of the build date or the date of any of the
    equipment. So far I've been able to identify that I have a hayward super pump,
    with stripped threads that I'm replacing. While the pump is down I would like to
    replace the gasket under my multiport as there is a decent leak there, but I'm
    unsure as to what brand or model filter I have. It appears to be faded black in
    color. It is fiberglass and what's left of the label identifies it as
    Pac Fab Incorporated which from research I know makes equipment for pentair
    though I haven't located a model that looks like it. Diameter is about 24
    inches. Any help is appreciated.
    Hayward super pump
    Centurion 1 hp single speed motor
    Pac fab / pentair sand filter
    27 x 12 inground 11,000 gals
    Stroud, Ok
    22,551
    Re: Need help identifying my sand filter
    It's either a Tagelus TA-60 or a Sand Dollar SD-60, with a 262506 multiport valve. You can buy a Go-Kit-364 O-ring kit which has all the O-rings for that filter. They also make a clamp kit which includes the clamp and O-ring.
    Apr 2015
    Stroud, Ok
    4
    Thank you so much for all of your help.
