Results 1 to 7 of 7
Thread: SLAM cut short question
    Oct 2014
    Magnolia TX and Watford City ND
    40
    Long story short, my wife tests the water last week and comes up with 0 FC on our 2 month old pool. (When I have time, I will post up some pics) We were using tablets for the first 2 months to allow the CYA level to gradually increase. That goal has been accomplished. CYA = 50.
    On 4/5 the FC = 4 and CC was .5. On 4/14 FC = 0 and CC = 0. I think my wife is on board with regular testing moving forward because she spent last week SLAMing the pool. Unfortunately, I work a rotational schedule which meant she was on her own and grew tired of the process. She tested daily and added chlorine to shock level once a day but after 4 days was done.
    She did not perform the OCLT before stopping. The water is clear. My question is if my CC level remains at .5 or lower, am I ok or do I need to SLAM?
    25K IG gunite pool / PebbleTec plaster / 2HP Hayward 2 speed pump / Hayward 525 SQ/FT SwimClear Cartridge filter / Tiger Shark QC robot / TF-100 test kit / Stenner pump X 2 - Chlorine and Acid
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: SLAM cut short question
    It is jot too late to do the OCLT. If you pass that then you will have the trifecta. But, it seems like you are in pretty good shape.
    Oct 2014
    40
    I will be home in a few days and will attempt the test. Is it possible to have a problem like algae and have CC be .5 or less?
    38,275
    Short answer is yes. All 3 criteria have a purpose. If the water is crystal clear and you sure no CC ... Odds are good the OCLT will be a pass.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Sounds like you need to do it. To reply to your Title, there are no shortcuts to SLAM.
    We have a couple or more slow ones this year already, and it's clear people are not keeping up the procedure when we see this.
    It is imperative that the FC has to get high, stay high, and stay high until everything is killed. When this is done properly, and in correct proportion to Cya, the pool will turn around. Unfortunately, if you let it slip, it will take time. Without knowing a little more, you are likely in the middle of this one. I would start anew with it, and get it going as if it were a brand new slam. If it's half or more done, then it won't take too long. Let us know when and if you need some help. We'll be glad to pitch in and help you through.
    Essential Links:
    Oct 2014
    40
    When I get home, I will perform a OCLT and go from there. Pumps on or off during the test or does it matter?
    Smykowski's Avatar
    Sep 2011
    3,065
    Pumps on.
