I have an intex rectangular ultra frame above ground pool 12x24. When installing I had to use a sand base because of the giant rocks in our Arizona dirt. It was compacted and I used wood base for the legs and unfortunately didn't use a wide enough base for each leg and the u shaped legs completely buckled on one side of the pool. The pool was only filled for a total of 4 days. I noticed a crease on 3 supports which in a matter of a couple hours completely crumpled the corners of the supports. I'm under the impression they don't have replacement pieces. Anyone have an idea as to what I can do to rig up some new leg supports?
