Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: intex ultra frame u-shaped support legs buckled!
    Apr 2015
    Lake havasu city, az
    11
    I have an intex rectangular ultra frame above ground pool 12x24. When installing I had to use a sand base because of the giant rocks in our Arizona dirt. It was compacted and I used wood base for the legs and unfortunately didn't use a wide enough base for each leg and the u shaped legs completely buckled on one side of the pool. The pool was only filled for a total of 4 days. I noticed a crease on 3 supports which in a matter of a couple hours completely crumpled the corners of the supports. I'm under the impression they don't have replacement pieces. Anyone have an idea as to what I can do to rig up some new leg supports?
    Intex rectangular ultra frame above ground pool 12x24x52"
    1600 gph sand filtration
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: intex ultra frame u-shaped support legs buckled!
    Welcome to the forum!
    Measure the size of the tubing. If it is a standard electrical conduit size --it will be close-- and ask several of you local electricians if they can bend that size of tube. If they can, you can have some bent. Leave the ends a few inches long, so you can cut them to fit.
    Another option is to talk to local automotive exhaust system shops (like Midas) if they have a comparable size tubing, and would they custom bend some for you.
    May 2014
    Lake Forest, IL
    53
    Did you just buy the pool? I would think if you contact Intex they would help you out. Did you try calling them and see if they can send you some legs ASAP?
    If you bought from a big box store - call the store manager and tell them you only had the pool 4 days and they will pull some legs out of another box and trade them out.
    Intex Ultra Frame 16' by 48" deep - Pentair Superflo 1.5 HP pump with sand filter, Hayward H150 Heater, Hayward Skimmer and 2nd return
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Casey's Avatar
    SW PA
    10,450
    Was the pool level within an inch?
    Apr 2015
    11
    The pool was level but the weight of the water made the legs smash into the sand. I didn't have a big enough wood piece for the legs to sit on and it bent around it.
    That white u shaped leg pictured isn't the same one for my pool. I saw those on ebay and it Wasn't the same.
    I think we are going to try and get a piece of pipe and use it as a sleeve to slip the original legs In. We will bend the pipe and cut the bottom off the original legs So we can just Basically reinforce the supports and create a new leg without worrying about the fitting that goes into the top piece.
    Apr 2015
    11
    I bought the pool online at vminnovations and haven't checked on their return policy yet. I am pretty sure we can make something work that'll actually be a better system than the original. I'll post pics with a solution when we get it figured out
    Apr 2015
    11
    Intex does not have replacement part. They said possibly by beginning of next month. They also wouldn't cover under warranty because of the sand base. I kind of figured that much though.
    Apr 2015
    11
    we finally got the pool drained and this is the total carnage on on 3 legs on the 12 ft. Side. Just wanted to share how important it is to have your base for legs the correct size and that was only max filled with water a total of 5 days.
    Have you figured out a solution to your problem? I need to replace 4 of these support legs because of rust. I called yesterday and was told they are out of stock and have no idea when they will be back in stock. I don't know what else to do. So disappointed.
    Just checked this morning and they are now in stock. YAY
    http://www.intexcorp.com/10937.html
    Apr 2015
    11
    We came up with a very sturdy solution. I didn't want to use theirs anymore haha. And I'm impatient and didn't want to wait for the legs to be in stock. So with under $25 each leg we replaced 9 of them that were bent and starting to bend out of the 18. We used emt conduit and welded together a new leg. Notching the tops to sit under the horizontal support bar. We then used the sides of each original leg with the little white clip thing and slid it in the conduit making this the piece that hold it in place. Pictures are going to be posted in the next comment
    Apr 2015
    11
    It won't let me post anymore pictures.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    To post more pics, use an online pic hosting site like photobucket and copy/paste the link into your post.
    jmcdtucson's Avatar
    Jun 2014
    317
    Or become a lifetime supporter of TFP.
    I used 16x16 pavers (4" thick) and glad I did - just for the piece of mind of knowing those things are never going anywhere.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Apr 2015
    11
    Thanks for the photo bucket info. I'll work on adding more pics. I ended up using 3-2x8 boards under the legs. That works extremely well so far. I learned alot after the first fill of the pool haha. This time its done right haha
    Apr 2015
    11
    Apr 2015
    11
    Apr 2015
    11
  20. Back To Top    #20
    Jun 2014
    Roseville, CA
    343
    I think King Kong could do a belly flop and all will still be well!
    Good job!
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
