Thread: Swg levels or normal with low cya? Help
    Feb 2014
    Sarasota
    43
    I got done with a slam a few weeks ago. I have my cya at 50/60. I've been doing trial and error with the swg to dial it in at the lower cya. So my question is. Tonight I tested my Fc and it's at 4.5. Which is 0.5 less than the 5 minimum recommended in pool math (normal without swg). Should I slam or should I be good since I am still over the 3 recommended with a swg (even though my cya is much lower than swg recommendation). I guess this question more so asks, is pool math accurate, if you are not within the recommended ranges? I am going to bring up my cya to 70ppm. Thank you
    11,000 gallon gunite kidney pool. Krystal Krete blue pepper interior finish. Pentair Superflo VS pump, Pentair Clean and clear RP 100 filter. Goldline blue essence with T-15 SWG. Savi sol LED. 4 deckjets
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Swg levels or normal with low cya? Help
    You are fine maintaining your FC 4-6. Definitely get your CYA up to 70-80 asap.
    Stick with these levels for swcg,
    Water Balance for SWCGs
    PoolMath is good for everything except adjusting PH when the PH is lower than 6.8 or higher than 8.2. The PH calculations are necessarily approximate, and the approximation used is designed to work reasonably well between 6.8 and 8.2, but can get fairly far off outside that range, more off the further outside that range you go.
    Having FC go 0.5 low once is not a big deal as long as you notice quickly and correct it.
