Thread: How to clean cartridge filter?
    Apr 2015
    Sebastopol, CA
    46
    New to the forum, searched around a bit, but did not see answer to this...
    I normally just hose off my cartridge filters in my Jandy CL-580. Is there any reason to soak them in TSP, or acid wash?
    18,000 gallon in ground pool built 2008, PebbleSheen surface, Aquapure salt system, Jandy 580 filter, Polaris sweep with booster pump, 2 stage filter pump, Suntopia solar heat; Marquis 630 ultimate spa, 2008, 390 gallons, built in ozonator, Saltron Mini Salt Water chlorine Generator for spa
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Apr 2015
    Sebastopol, CA
    46
    Re: How to clean cartridge filter?
    Thanks! I should've searched better.
    DFW, TX
    24,514
    No worries, lots of stuff here. Takes a little time to learn your way around.
