Thread: Is this safe to swim in?
    Mar 2015
    Harvey, LA
    300
    I'm gearing up for a drain/refill gradually, but I'm curious if the numbers I have are especially dangerous to people...I'm sure the numbers are bad for the equipment and finish, but can we swim in this some while we drain/refill to reduce CYA? The water is very clear, but I know that clear water doesn't necessarily equate to water that is safe to the skin...
    FC:26
    TC:27
    pH: 7.2 (Of course with the FC so high, I don't know how (in)accurate this number really is)
    TA: 170
    CH: 1000
    CYA: 200+
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Is this safe to swim in?
    If the water is clear and the FC level is below the recommended SLAM level for that crazy CYA level, which I believe it is, it's safe to swim but you have obvious issues to work out.
    Sent from mobile device. Beware of brevity and spelling errors!
    Isolated Spa - 345 Gallons
    I am worried about that PH reading. The PH test tends to be way totally wrong when FC levels are that high. I strongly suspect that the actual PH is way too low. If so, the low PH will be rather irritating, especially causing stinging eyes.
