Right in the middle of SLAMing we got slammed with a huge downpour that added a good two inches of water to the pool. Do I need to start all over or just maintain my 16 FC level?
Thanks for the advice. PH came up so I added some more acid. FC came down one point. CYA was at 40 prior to rain but I did not reckeck it. TA was unchanged. Will check FC level just after dark and adjust if necessary.
From what I have read on here, if your FC is over 10 or at slam levels your PH will not be accurate. I am only testing FC. I started my slam yesterday. Good luck.
Thanks!That's a sweet river bed n run off system Tim!
