Results 1 to 18 of 18
Thread: Installing our first framed pool, an AG 18 x 48 Intex Ultra Frame, western WA
    Apr 2015
    Western, WA
    37
    Hello TFP! I've been scouring this forum and have really been inspired and educated by the members here--thank you!
    We have had two seasons with a 12x30 summer escapes ring pool, but our kids are growing fast and so we are moving up to an 18x48 pool. I'll attached pics to share the progress. Please chime in with any suggestions for us!
    Marked out an 18' diameter and 20' diameter circle using a piece of rebar as a center post, measuring out 9' with a string and walking in a circle around the rebar with spray paint on the grass. Repeated with a 10' mark on the string. Worked perfectly and took mere minutes.
    Then, using an edging spade, when around the entire edge slicing through the grass. I also used the spade to cute narrow pizza shaped slices in toward the center of the circle. This helped getting the grass out.
    Out comes the shovel and wheel barrow. Nothing but physical labor here. But progress was steady and encouraging.
    Jason
    AG Intex Ultra Frame 18x48 - new for '15. TF100 test kit. Intex 3,000 gph sand filter/pump, Solar Cover, Intex magnetic pool light, Hayward Skimmer, Laars 250kBtu/hr NG heater. Intex SWG.
    Apr 2015
    Western, WA
    37
    Re: Installing our first framed pool, an AG 18 x 48 Intex Ultra Frame, western WA
    More pictures from today.
    Casey's Avatar
    SW PA
    10,444
    This, my friend, is the hardest, most physically draining and most IMPORTANT part of owning a swimming pool! Good luck! I don't envy you!
    Jun 2013
    Seguin TX
    192
    Looking good and I feel your pain, however when laying on your back in the pool with a cool drink will be your reward
    2017-Intex Ultra Frame 16x48 5000 Gallons
    Intex 2800GPH Pump with 14" Intex Sand Filter
    My Intex Pool Setup Video :Intex pool rises from the ashes - installing and leveling - EP-72 - YouTube
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Good work! As everyone says, this is the hard part. Putting up the pool is easy and floating in it is easier still!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    I'll bet you expanded the children's vocabularies today. And if not, you will when the sidewalls go up.
    One word: Motrin.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,492
    Great start! That is a LOT of work! Your poor body!
    Kim
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    This reminds me of when we first set up our pool.
    On the box it proudly proclaimed "Ready for water in just 45 minutes! "
    It turned into a running joke with us.
    Has it been 45 minutes yet?
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Casey's Avatar
    SW PA
    10,444
    Quote Originally Posted by Beens View Post
    Lol... Yeah right!
    Apr 2015
    Western, WA
    37
    After a month away due to work, I put in some more time last night. Getting closer to level. The yard has about a 4 to 5" slope from one side of the pool space to the other (fence side is low side), so I am working on addressing that. Embedding a photo below.
    Have a new Intex 3,000 GPH sand filter onsite from Amazon, picked up a used NG pool heater off craigslist that I will work on getting set up soon as well, a Teledyne Laars 175k BTU unit. Hayward skimmer here from Amazon, just need to install it once the pool is set up. Intex pool light from Amazon here. 18' solar cover from Amazon here.
    Will 'play sand' from Lowes work for the sand filter? Or do I need specifically the #20 silica sand? This play sand is very fine and is pre-washed per the manufacturer.
    Hoping to set the pool up this weekend.
    [IMG][/IMG]
    [IMG][/IMG]
    Jul 2012
    Tallahassee, FL
    30,492
    Good job with the pictures!
    Nope-----no play sand. It does need to be "pool" sand. It is quite different (not sure what the difference is but.........
    Good luck with the leveling of the area! Have plenty of adult drinks on hand to help with it! LOL
    Kim
    Apr 2015
    Western, WA
    37
    Thanks Kim. In the last few minutes I did some searching on the forum here about the play sand--yes I will stay away from it. Local Ace does not have the silica, but can order it in. Local pool store has #40 bags for $13.18/each. I'll get it from the pool store. I have never been in there--hopefully this will be my only visit.
    I need some CYA--should I get that @ the pool store too?
    I have bleach, muratic acid and borax already.
    Jul 2012
    Tallahassee, FL
    30,492
    I get my CYA from Walmart- stabilizer is what the call it. Just look at the ingredients
    When you walk into the pool store just put your fingers in your ears and say lalalalalalala Oh and look at all of the cool toys they have!
    Kim
    DFW, TX
    24,485
    Cyanuric Acid, CYA, Stabilizer. I get mine at Lowe's in the pool/garden section.
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    I am right there with ya on the leveling. I just finished mine with about the same slope and the same pool. The digging and leveling took like 2 weeks with my bad back. I had the sand in and leveled in 1 day, and the pool assembled and half full in one day. By the next evening the whole family was in the pool!
    I bought my CYA at walmart for about $13 for 4 lbs. Just to give you a price comparison for when you go to the pool store.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Apr 2015
    Western, WA
    37
    Just hauled away and unloaded my 3rd trailer of dirt/sod. That makes over 6,000 pounds so far! We are working on locating a strong college kid to help me finish the prep work tomorrow so we can set this thing up!
    Jul 2012
    Tallahassee, FL
    30,492
    Good luck finding a college kid willing to do some grunt work! LOL Maybe a teenage boy still in highschool?
    Kim
    Casey's Avatar
    SW PA
    10,444
    This is the hardest part. You're almost finished. Don't take anybshort cuts now. See it through to the end!
