Thread: Leak Detection
    Jul 2008
    southern Illinois
    10
    Leak Detection
    Leak Detection in Pool School states "The way to tell if it's the pool or the plumbing is to plug all the inlets and outlets....
    My question - How does one plug all the inlets and outlets? Does that mean turn the pump off, turn all the valves in the closed position, and then watch the water level?
    Duchess 16'x40' FG, 25,000 gal, SD80 Filter, 1.5 hp SuperFlo, Intellichlor SWG
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Leak Detection
    No. Shut the pump off, put the winter plugs in the returns and put a gizmo or plug in the skimmer(s). That eliminates the filter/pump and all of the return and skimmer plumbing. Main drain leaks are another issue. Much more difficult to plug that and isolate it, but it can be done.
