Results 1 to 10 of 10
Thread: Adding Pentair iPhone controller
    Apr 2015
    Sag Harbor, NY
    21
    Post Adding Pentair iPhone controller
    I have a similar question. Starting the process of upgrading the pool hardware for a recently purchased house. Replacing an old Hayward pool pump with a Pentair Intelliflow, variable speed pump. With this, will add a controller that will link to the pool heater as well. What I am confused about is all the different remote options. I have very good wireless coverage throughout the house and the property and plan on redoing the whole pool in a couple years. so not interested in hard wiring a controller, yet. So if all i want is the ability to use the iphone/pad to control, for now, is the right one Pentair Easytouch PL4 - Single Body - w/ScreenLogic Wireless Bundle - Part # 522353.
    Thank you
    Re: Adding Pentair iPhone controller
    Welcome to TFP!
    Correct, the 522353 package includes the Screen Logic Internet adapter so that any PC, iPhone, iPad or Android phone/tablet becomes a remote control. That does pretty much make all of the Pentair remotes unimportant/obsolete.
    Apr 2015
    Sag Harbor, NY
    21
    Thank you.
    Apr 2015
    Sag Harbor, NY
    21
    pentair PL4 schedule function????
    So I have it all wired in, communicates with network, VS pentair pump connected and interacting with pl4. Heater turns on and off via pl4. However, schedule function does not work. Activated to run 8 to 4 every day. System will not recognize. Driving me nuts. Any tricks here?
    On a separate note, the app is terrible and the windows program keeps crashing my computer, despite upgrading firmware on network modules.
    Primary issue is the scheduling issue. Any insight?
    Thank you
    Pool: 40k gallon pool shaped as a trapazoid. 10ft / 3ft deep
    Filter: Starite S7MD60 / Pump: Pentair Inteliflo multi speed pump /Robo Cleaner: Kreepy Krauly 830
    Pool heater: Rheem PM m336a (Legacy) / Control: Pentair EasyTouch PL4 Control
    Light: Pentair IntelliBrite 5G White
    VetteBlue's Avatar
    May 2015
    Maryland
    23
    I wish my pool builder had suggested this when I built mine last year. I never even considered that there could be a phone app to control and monitor it. Is that all you need is to add the 522353?
    17x35 Oval In Ground Vinyl Pacific Pool, Pentair Intellichlor IC40 SWG, Sand Filter, Pentair Kreepy Krauly Legend Pressure Side Cleaner, LED Lighting System, 16 Mil Clear Solar Blanket, TF-100 Test Kit
    Mar 2011
    441
    Quote Originally Posted by VetteBlue View Post
    You need to add the 520500
    20X40 30,000 gallon gunite pool
    VetteBlue's Avatar
    May 2015
    Maryland
    23
    Quote Originally Posted by racket View Post
    Even though I don't have any kind of interactive controller now? Basically just a steel box mounted to a post. No readouts or settings except on the IC40 SWG itself.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Yes VetteBlue, that's what you need (522353) if you currently have no Pentair automation. That's the least expensive anyway. You can spend more, with more features, but that's the entry level (screen logic) unit. Basically, you remove whatever it is you have in there now ("just a steel box, no readouts") and replace with the easytouch PL4 + screen logic. This can be quite an endeavor, and you may want/need the help of an electrical contractor. Be advised that this system does not provide for a sub panel in the area below the OCP. That's where the spending of more money like the straight Easytouch would get you. With the PL4 you will need to mount a separate sub panel for control breakers (if applicable).
    Racket, i think you didn't notice there are two guys asking questions here. If you have existing Pentair automation like Yetis, yes, you need just the 520500 for screen logic.
    Factory Warranty Station for:
    Apr 2015
    Sag Harbor, NY
    21
    Yes, you need an electrician to install the PL4. High voltage wires and such, not something to mess around with. I hope Pentair upgrades the app, as in its existing state, its almost unusable. However, back to the primary issue. Anyone have any trouble shooting experience with the schedule function? Just does not work.
    VetteBlue's Avatar
    May 2015
    Maryland
    23
    Quote Originally Posted by yetis View Post
    Between the panel costs and the electrician, it sounds like it's probably not worth it. Apologies for hijacking the thread!
