Thread: Hot Tub High Temp
    Apr 2015
    Hattiesburg, MS
    1
    Hot Tub High Temp
    I can not lower the temperature on my Island Spa hot tub. It has been locked on a high temperature.
    Moved post to start a new thread
    divin dave
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Hot Tub High Temp
    You may check out the Island Spa web page to find a manual, or failing that the closest dealer seems to be about 70 miles away
    Spa & Tub Manufacturers, Inc.
    3612 Hwy 90 Gautier, MS. 39553
    Telephone: 228-497-0035
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    The only thing I know to try is turn off the circuit breaker for 10-15 minutes and see if that resets it. Otherwise, I'd have to call the people I bought the hot tub from.
    Jul 2014
    Peoria, IL
    389
    Is it overheating? If so, could be a bad limit sensor. That is what tells the heater to turn off. Is there a code that is showing up on the controller?
    Or do you mean that you cannot physically turn the temp down? If that try the breaker reset, if that does not work you may have to replace the keypad??
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Dec 2014
    Sydney, Australia
    43
    http://www.artesianspas.com/Mkt-Down...nersManual.pdf
    Assuming your keypad looks like this... P28, some kind of parental/child lock might be on...
    8M x 4M Inground Concrete, 40k Litres, Waterline Tiles/Quartzon, Viron P320 VS Pump, Sand Filter(Glass Media) Astral VX-9 SWCG, Heatpump w/ Solar Cover. Zodiac V3 4WD Robot. Bullfrog A8D Spa(1800Litres).
