Thread: Backed to the sunroom kitchen island placement.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Hey folks,
    So I'm planning out my outdoor kitchen and one the options I'm considering is to maybe back the island (or at least the portion of it where the grills are going to be) to the exterior sunroom wall (vinyl siding). I'm thinking, I can install a fire/heat proof barrier behind that also goes up maybe two feet or so that can be titled/stoned as a nice backsplash. Of course this design still worries me for obvious reasons. I'm also worried about not be able to appropriately vent it at back.
    What say you folks, am I crazy to even consider this option?
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
    Jan 2013
    Friendswood, TX
    320
    Re: Backed to the sunroom kitchen island placement.
    Do you have a sketch of what you are describing? How close would the closest grill be? Gas or charcoal? Really need some sketches.
    I have a double burner close to my house but it's brick not siding. I believe there is a regulation on this. 18 or 24 inches I think.
    Also need to consider smoke staining your siding.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Good points on the regs. No sketch yet as I'm pretty busy with a gazebo pad at the moment, but will be putting one together in the next several weeks and will definitely post it. Appreciate the input!
    cwescapexlt4x4's Avatar
    Jul 2014
    Litchfield Park, AZ (PHX metro area)
    461
    i would be concerned with this with Vinyl for sure, and if not gas you have to consider sparks/embers as well.
    Chris - aka cwescapexlt4x4
    (Build 8/26/14 - 10/17/14) in-ground Presidential Pools 15K gallon salt water pool Pentair Inteiliflo pump, Regal Blue Pebble, Clean & Clear filter, in-floor cleaning,
    LED light, 3' sheer spill, 2 benches, large Baja step. / Pergola by Booth Built 19W x 14D // Outdoor Kitchen, W/Primo grill and BBQ Coach kit for the island.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Yes that's certainly is my concern as well, hence the thought of building a fireproof barrier/backsplash. My bigger concern at is point is the back venting. Also I definitely don't want to do anything against code..
