Thread: Backwashing- Such a Waste
    BrianT.'s Avatar
    Apr 2015
    Palm Harbor
    5
    Has anyone come up with a way to filter the waste water from backwashing and return it to the pool?
    Having to replace the water and the chemicals... It just seems like such a waste.
    Thanks
    18k gal. IG, Plaster/Diamond Bright, 1 hp Flotek pump, Hayward S310T sand filter, Great White auto cleaner and inline chlorinator.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: Backwashing- Such a Waste
    Not really. All filter systems have some inherent "waste" involved in the cleaning of the filters. Eitehr by back-washing of sand/DE filters or taking cartridges out to rinse them.
    Some folks have talked about capturing the water and using it for landscape irrigation. You would probably need a fairly good sized cistern to store the water though.
    Support the site
    Most people who are worried about this kind of thing get a cartridge filter. It still takes a little water to clean the cartridges, but it isn't pool water and it isn't nearly as much water as backwashing.
    The is a thing called a recovery tank, which filters the backwash water and returns it to the pool. You don't see them very often as cleaning the recovery tank filter is quite annoying, worse than cleaning a cartridge from a cartridge filter.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It doesn't get wasted where I am because I don't have to go to sewer with it. I use it for my backyard watering.
    But right here, where we are in dry arid country, our municipalities require it to go to sewer when it could water landscapes. Foolish and wasteful that is IMO.
    Essential Links:
