Results 1 to 7 of 7
Thread: Just opening a hottub
    Apr 2015
    East Wenatchee WA
    39
    Just opening a hottub. Its fiberglass approx. 350-400 gallons... Can you give me a quick list of goals for my chem numbers. I have a T100 kit
    Thanks!!!
    I should have given this info: Source water is municipal with a ph of 7.8, TA of 90 that's all I have tested so far.. FC is 0 and so is CYA of course. I have some CYA should I go ahead and put some in skimmer. I want to use bleach as my chlorine product.
    15'x30' oval AGP. 12000 gal. 1 HP pentair pump. 19 inch sand filter.
    Auto vacuum thing that works through skimmer. Solar cover.
    OLD 400ish gallon Cal Spa hot tub with two new pumps (ouch)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Spa Calculator for BBB?
    Apr 2015
    East Wenatchee WA
    39
    Thank you!!! All set... almost...
    Apr 2015
    East Wenatchee WA
    39
    This Forum is so helpful!!! Day 3 of hot tub start up and my water is sparkly clean, numbers are good and three kids ages 9 to 18 are in and out of it all day (because its new and the pool isn't built yet)... anyway...thank you thank you. I even moved my TA from 100 to 50! How's that for beginners luck!!!
    DFW, TX
    24,513
    Re: Just opening a hottub
    Good work! Don't skip adding borax to your hot tub. Somehow I missed it for a year, even though I've had it in my pool for years. Added it last weekend and it makes it even better!
    Apr 2015
    East Wenatchee WA
    39
    I know I read somewhere how to add borax and acid to maintain a balance. I will search again for that post. Thanks for reminder!!!
    DFW, TX
    24,513
    Here you go.
    http://www.troublefreepool.com/threa...es-Why-and-How
    PoolMath will also tell you how much borax/acid to add.
