Results 1 to 19 of 19
Thread: Hayward ColorLogic 4.0 Light?
    Feb 2015
    Austin
    133
    My PB is trying to talk me into this instead of the standard white halogen. The reviews on Amazon are horrible. It looks like they die right after the warranty expires and cost close to $1k to replace. Anyone use this light?
    Feb 2014
    Upstate, NY
    390
    Re: Hayward ColorLogic 4.0 Light?
    I have the Hayward LED light. So far so good. No problems although its been only a year now. The standard halogen is obsolete IMHO.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Jun 2013
    Erie pa
    68
    I also have a hayward led light no problems going on 4 years.
    16x32 vinyl ig with foxguard steel walls,gli liner ,hayward de filter,hayward heatpro heat pump,hayward colorlogic 4.0 led.pentair circular weir skimmers.hayward sharkvac xl robot,gli mesh cover.polk atrium speakers,sonos music system.erie pa.
    I had a colorlogic for about 3 years. It has not worked the last 2 years. It seems the reviews were correct regarding mine. It got water inside after a couple of years and shorted out. It had very, very few uses on it. I always tried to reserve the bulb by making sure not to use it unless necessary, but in the end the leaking go it.
    I am online now trying to find something better to replace it with or determine if they have changed the design to better withstand being submerged.
    Donna
    18X37 Grecian Vinyl Liner, X-Stream Slide, 1 1/2HP Hayward Pump, 3/4HP Polaris Booster, AquaRite SWG, Jandy AE3000 Heat/Cool, Jandy Deck Jets, 4.0 Colorlogic Light, Polaris 280 Cleaner
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    A lot of changes have been made to the light over the years. Much heartier than the past.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Sep 2010
    Orange County, CA
    52
    I probably got 4 years out of it before one of the colors died. Now I'm trying to figure out if I'll replace it with another Hayward, or try one of the other brands.
    Southern CA 30K gal Pebble Pentair WhisperFlo 1HP 2 speed Hayward DE6020 filter Paramount Debris Canister Goldline/Hayward AquaRite Pro SWG (T-CELL 15) Sense & Dispense (acid) Pentair IntelliBrite 5G and GloBrite Inter-Fab G-Force slide Jandy deck jets Lion head spout Dolphin Premier Cleaner Taylor K-2006 test kit
    I have standard halogen but what I found with the colorlogic was its nit that bright with a blue liner pool. The halogen is so much brighter where the colorlogic is dim....
    Feb 2015
    Austin
    133
    Quote Originally Posted by Hayward Pool View Post
    That's pretty much word for word what my PB said when we were discussing the upgrade...almost like it was part of a sales brochure.
    No offense, but it's pretty hard to trust a statement like that, knowing the source.
    My PB also argued with me that the ColorLogic was brighter than the standard white, despite all the things I've read here and in online reviews. Is that true? Which is brighter, the ColorLogic or the standard white?
    36 x 16 IG, SWG, FAFCO Solar Heating System, WetEdge Primera Stone Sky Blue Treasure, 8.5' - 3.5' depth, 6' S.R. Smith Flyte-Deck II Dive Stand, Interfab X-Stream slide, 27k gallons, doggy tanning ledge w/ 2 bubblers, 2.75 Hayward Tristar pump, Hayward 425 cart filter, Hayward T-15 Salt Cell, Hayward ColorLogic 4.0 light, Dolphin Z5
    I have this colorlogic 4.0 light and I have used it maybe 6 times over the last three years and it no longer works. After some research I guess there is not much to do except just replace it.
    The pool company installed the light but after reviews saying exactly the same thing that the light doesn't last I'd like to replace it with a Pentair and I'm wondering if the housing fits all the lights or am I stuck with Hayward?
    Northeast PA (Mt Cobb) 16,000 gallon in ground salt pool with all Pentair automation and Intelliflo VS pump. Also part of the pool is a two 5-horsepower 3-jet Badujet swim system. For heating we use a 384 sq-ft Heliocol solar pool heating system and additional solar from the 160 sq-ft house solar heating system.
    Oct 2014
    Elizabeth
    426
    Take a look at the 12v color lights on the market. Very good reviews.
    Hayward Pool Tech
    I just wanted to add this about the Hayward. I benched the light and found that water had seeped into the light and it was easily visible what had happened. It is a very poor design where the seal between the back plate and the glass is made. The SS plate is thin, the tab is too long and is preventing the rubber at the top of the light from making a perfect seal so eventually it had to fail.
    Although it worked well and I got a few years out of it water was what did it in.
    Hayward was made aware of the flaw but they choose only to say the warranty period has expired.
    Things break, I get it but clearly this was a design flaw.
    John
    Jul 2012
    Nashville, TN
    12
    Have a link to the reviews? Only ones I can find are on Amazon or Leslie Pool supply and they are not very flattering.
    Jul 2012
    Nashville, TN
    12
    Quote Originally Posted by jongig View Post
    ....snip.....The SS plate is thin, the tab is too long and is preventing the rubber at the top of the light from making a perfect seal so eventually it had to fail.....snip....John
    Curious, do you think sealing the outside/lip/area with silicone would have prevented the failure? Several of the negative Amazon reviews point towards water leakage. I'm wondering if sealing the unit before installation might help them last. I admit we shouldn't have to do that to a $500 item, but we are a little limited for options in the pool LED light market.
    Hayward, is this a known point of failure? Have you guys updated the design? Is there something that installers could be doing better that would help improve life expectancy?
    If you go back to my post a couple up you'll see I had the Hayward and it failed due to water leakage. Hayward has since sent me a replacement even though mine was out of warranty a couple years. I had done a good job of documenting what I believed to be the point of failure to them which probably helped. I think the back plate needs to be stiffer but on the new one they did shorten the tab at the top of the light which I believed to be the actual failure. It's possible that this new one will not leak and only time will tell. I'm also considering removing the light in the winter months just because I don't want to go through this again. If I can get 10-years out of the light I'll be okay with buying a new one but not after three years.
    Feb 2016
    Houston
    323
    I am hoping this solved the problem and Hayward has redesigned their lights. One PB wants to charge $800 for a Hayward LED light, so it better last more than 1 or 2 years.
    Jan 2017
    Cape Coral, FL
    3
    Installed Hayward colorlogic in my new pool in 2012. Failed in 2015. Failed again in 2017. 2017 failure was water incursion. Hayward variable speed failed in 2017, bearings. Pump controller failed shortly after. Have written off all Hayward products.
    Jun 2011
    Innisfil, Ontario, Canada
    55
    Are these things failing over the winter? I ask because my neighbor removes the lights (Twist out), removes the bulbs and lets the housing fall down to the bottom of the pool (on its cord) to ensure its safe from the ice.
    I just had Colourlogics installed in (12v) so will see how long they last.
    DJ_MOORE's Avatar
    Jul 2016
    Cleveland, Ohio
    5
    I have 2 Colorlogic 4.0 lights I will be installing this summer. Not very encouraged by what I read about them but will definitely be taking a closer look at the issue w/ the seal in back under the stainless steel plate before installing them. The pool I have is a reclamation project going on 3 years now. I was told by PB the 2 lights I already had in it needed updated for the vinyl liner. Shame cause the original 2 lights in it still worked - even after 45 yrs!
    Refurbished Hybrid IGP (Concrete Base & Fiberglass Walls) now w/ a Liner, 20' x 40' Double Roman End, Est. 28,000 - 30,000 gallons, Pentair Intelliflo VS Pump, Pentair Quad 100 DE/Cartridge Filter
    Jul 2014
    Bryan
    1
    I was wondering what was better stainless or plastic for a chlorine pool.
